Heli_av8tor Posted November 18, 2018 Report Posted November 18, 2018 Here's my version of a lift arm for the DeWalt DW788. I know, how many ways are there to skin a cat. I wanted something very simple to build and use. This design features a tapered catch that slides under the existing plastic housing by the speed control. The arm (1/8" x 1" aluminum) is positioned so that the latch pin normally sets about 3/8" away from the black plastic housing. The arm can be raised or lowered without interference. With the arm fully raised the latch pin clears the housing just enough to allow it to be pushed left to contact the yellow arm. To latch the arm in the up position simply raise the arm with an up-turned right hand and use the thumb to push the lift arm to the left. Allow the arm to come down and trap the latch pin under the housing. To lower the arm simply lift it up and the latch pin pops away from the housing allowing the arm to drop. The latch pin is a 1/4" x 20 flat head phillips screw. I'm sure it could have been used as is but I decided to turn a shoulder at the base of the head. This eliminates wedging the housing between the screw head and the nut. The mounting holes in the lift need to be positioned accurately to keep the arm as high as possible but still allow the latch pin to clear the housing. The arm only droops about 1/8" when held up by the lift. OCtoolguy, stoney, Karl S and 3 others 5 1 Quote
Karl S Posted November 18, 2018 Report Posted November 18, 2018 I like your lift, thanks for showing us, Looks like a good solution. OCtoolguy 1 Quote
Rockytime Posted November 18, 2018 Report Posted November 18, 2018 Easy peasy, nice and easy! Good thinking. Almost wish I had a 788 so I could make and use it. Very good. OCtoolguy 1 Quote
amazingkevin Posted November 19, 2018 Report Posted November 19, 2018 The more the merrier! Love to see better mousetraps for the infamous Dewalts! OCtoolguy 1 Quote
OCtoolguy Posted November 19, 2018 Report Posted November 19, 2018 Now, why didn't I think of that? I bought the Jim Dandy lifter and so far it has worked great but I can see that yours is going to be just as good. Or better because it costs almost nothing. Quote
Heli_av8tor Posted December 21, 2018 Author Report Posted December 21, 2018 Now that I've got a couple projects under my belt with the DeWalt and this lifter I can report it a success and recommend the design. Using it has become automatic. Though I've not used any other design I can't imagine anything working better. Tom OCtoolguy and stoney 2 Quote
Heli_av8tor Posted December 21, 2018 Author Report Posted December 21, 2018 Oh, I have made one cosmetic change. Anal as I am I had to have mounting bolts that matched the others on the machine. Turns out the arm pivot bolt is the perfect length for mounting the lifter arm. I ordered a couple online. Tom OCtoolguy and stoney 2 Quote
JTTHECLOCKMAN Posted December 21, 2018 Report Posted December 21, 2018 You wonder why Dewalt never added something to their saws. At least give people the option to have the arm lift automatically or disengage it and let it drop like it does now. After awhile that arm does get heavy. most saws they lift automatically. Still love my RBI. More and more each day and I did not think that was possible. Anyone ever asks me what saw to buy?? Without hesitation an RBI!!!!!!!!!!!!!!!!! Best saw on the market. OCtoolguy and stoney 1 1 Quote
Hermit Posted December 23, 2018 Report Posted December 23, 2018 After reading about all the Dewalt lift arm issues, I must be the odd man out. I've never lifted the arm to remove/move a blade. I've always just removed the blade top and bottom. I feed through the top, tighten the bottom thumb screw first then the top. I never look under the table. Am I the only Dewalt user that does This? Seems so much easier than wrestling with a lift arm. Becomes second nature in no time and pretty fast at it. OCtoolguy 1 Quote
stoney Posted December 23, 2018 Report Posted December 23, 2018 On 12/21/2018 at 2:30 PM, JTTHECLOCKMAN said: You wonder why Dewalt never added something to their saws. At least give people the option to have the arm lift automatically or disengage it and let it drop like it does now. After awhile that arm does get heavy. most saws they lift automatically. Still love my RBI. More and more each day and I did not think that was possible. Anyone ever asks me what saw to buy?? Without hesitation an RBI!!!!!!!!!!!!!!!!! Best saw on the market. There really is no need to wonder John because it is the engineers and the bean counters. There must be some Dewalt owners that feel a lift arm is useful otherwise there wouldn't be models on the market like the Jim Dandy lifter. Just like I have stated in other posts once a scroll saw is on the market the manufacturers just can't seem to admit any issue and then there are the beans counters. Oh and by the way I have never test drove a Hawk but they would probably be my choice for a new saw. kmmcrafts and OCtoolguy 1 1 Quote
stoney Posted December 23, 2018 Report Posted December 23, 2018 Your lifter looks great Tom thanks for showing us. OCtoolguy 1 Quote
Roberta Moreton Posted May 2, 2024 Report Posted May 2, 2024 On 11/18/2018 at 1:08 PM, Heli_av8tor said: Here's my version of a lift arm for the DeWalt DW788. I know, how many ways are there to skin a cat. I wanted something very simple to build and use. This design features a tapered catch that slides under the existing plastic housing by the speed control. The arm (1/8" x 1" aluminum) is positioned so that the latch pin normally sets about 3/8" away from the black plastic housing. The arm can be raised or lowered without interference. With the arm fully raised the latch pin clears the housing just enough to allow it to be pushed left to contact the yellow arm. To latch the arm in the up position simply raise the arm with an up-turned right hand and use the thumb to push the lift arm to the left. Allow the arm to come down and trap the latch pin under the housing. To lower the arm simply lift it up and the latch pin pops away from the housing allowing the arm to drop. The latch pin is a 1/4" x 20 flat head phillips screw. I'm sure it could have been used as is but I decided to turn a shoulder at the base of the head. This eliminates wedging the housing between the screw head and the nut. The mounting holes in the lift need to be positioned accurately to keep the arm as high as possible but still allow the latch pin to clear the housing. The arm only droops about 1/8" when held up by the lift. What is the name of the thing that rests under the black plastic to actually hold the arm? OCtoolguy 1 Quote
Scrappile Posted May 2, 2024 Report Posted May 2, 2024 I wonder,,, (oh oh here we go), if you extended that piece of metal (the red piece) further in the back and attached a spring to it, you could make it so when you release the blade from the clamp the arm would automatically go up and stay like a Hegner does. I would not try it on any saw I had. But maybe some brave sole out there might. OCtoolguy 1 Quote
OCtoolguy Posted May 2, 2024 Report Posted May 2, 2024 1 hour ago, Scrappile said: I wonder,,, (oh oh here we go), if you extended that piece of metal (the red piece) further in the back and attached a spring to it, you could make it so when you release the blade from the clamp the arm would automatically go up and stay like a Hegner does. I would not try it on any saw I had. But maybe some brave sole out there might. That arm is pretty heavy so it would take a hefty spring. But....worth a try. Scrappile 1 Quote
