Travis Posted August 5, 2009 Report Share Posted August 5, 2009 What do you use for a workbench? Is it a real workbench? A chunk of plywood on sawhorses? Or are they your kitchen table? I'm curious about what y'all use. Mine consist of 2 TV trays for assembly, and a folding table that holds stacks of patterns and half-completed projects. Quote Link to comment Share on other sites More sharing options...
shadylady0447 Posted August 5, 2009 Report Share Posted August 5, 2009 I actually have a workbench in the shop where I do my cutting and sanding. But I don't have a dust collector in the shop so I usually do the spray or wipe on finish in the garage on the sawhorse table! But if I use acrylic paints in my project I do it upstairs in my craft room on an 8 foot folding table. But when I put a portrait in its frame I cut the backing posterboard sheet and do the final placement of the cutting on the kitchen table! I didn't realize I used so many different places to do a project until I really thought about it! Quote Link to comment Share on other sites More sharing options...
ugsduck Posted August 5, 2009 Report Share Posted August 5, 2009 I have a spare bedroom that I use for a "Hobby Room". This includes a multitude of things I have tried and some that I have stayed with. It is a large room with 4 large desks that I have topped with heavy one and a half inch kitchen worktops. The 1st stands apart from the others (Which are in a U shape formation) and is home for my Computer and Computer equipment etc. The 2nd stands under a large window and I use that for model building, sketching etc or anything that would benefit from a good natural light. This desk forms the crossbar of the U. The 3rd forms the left of the U and containers photograhic equipment such as a lightbox, lights etc - useful for photographing small objects. The 4th Forms the right of the U and now hold the scroll saw and scroll saw tools, blades etc. Lots of shelving around the room provide adequate storage for needed items. I use another smaller spare bedroom for spraying, painting, varnishing etc. Light sanding is also done here. I also use a wooden shed for things like heavy sanding, storage etc. A few years ago I used a small corner of the living room but once the children flew the nest I expanded a little .... Quote Link to comment Share on other sites More sharing options...
grampa Posted August 5, 2009 Report Share Posted August 5, 2009 I had a new kitchen a few years back and put parts of the old one in my workshop I use MDF for the tops that way when they get chipped I can turn them over or just replace them, the stock 4ft x 2ft sheets just slip straight in, I like a clean flat surface to work on so I change them about every 3 month............Paul Quote Link to comment Share on other sites More sharing options...
britetomro Posted August 6, 2009 Report Share Posted August 6, 2009 My work is done in my garage and sometimes out in the driveway with an easy-up shelter for protection from the sun. I have 2 work benches which I use. The first was built about 5 years ago and it was over built beyond belief. I wanted it to be strong and used 2 layers of 1" MDF for the top and bottom shelf. It measures approx. 6" long by 3" deep. I enclosed the bottom area to provide protection for various other pieces of equipment. The other work areas base is a fooseball table which my boys used a few years ago. I made a top out of 1/4" MDF and made it up in a honeycomb type manner by creating a cavity of 4" high pieces and assembled them with a top and bottom with 1/4" MDF. It is also very strong and measures 4' by 5'. A good size for laying out my frames during assembly as well as cutting full sheets of mat board which measures 32" by 40". If I get a chance this weekend, I will take a couple of photos to share. Ron Quote Link to comment Share on other sites More sharing options...
cyclistjim Posted August 7, 2009 Report Share Posted August 7, 2009 I built my work bench from a design on lowes. The only problem I had was how much it weighed. It not something I am able to pickup. But the weight makes it a very stable work bench. If I ever need to move it out of the shed I will have to disassemble it. http://www.lowes.com/lowes/lkn?action=howTo&p=Build/Workbench.html Pictures Quote Link to comment Share on other sites More sharing options...
woodinhead62 Posted August 9, 2009 Report Share Posted August 9, 2009 I use a few different types of tables myself. A got a couple of really sturdy electronic tables from a company that was throwing them away! Also, a few fold-up tables that I bolted to the wall; they work great for my router tables & belt sanders. I also acquired a couple of square restaurant tables that were put on the sidewalk by the dumpster. One of them has wheels, so I keep my drill press on that one. One mans trash is this man's gold! Quote Link to comment Share on other sites More sharing options...
Clayton717 Posted August 9, 2009 Report Share Posted August 9, 2009 I do all my work in my small shop, unless the project is to big. I have workbenches on three sides, two of them hold my tools and the other is where I do all my work. They are all built by me. the one i use for my work station started out as a train table, but found out didn't have enough time for 2 hobbies like that, and took up to much valuable space in the small shop (10 x 12) Quote Link to comment Share on other sites More sharing options...
wood-n-things Posted August 9, 2009 Report Share Posted August 9, 2009 I have a workbench and I also use my table saw top. I also use a work mate for some heavy sanding jobs out doors with the belt sander, as my shop vac really won't contain all of that sawdust created by a belt sander. I was fortunate enough to get some lower cabinets with doors when a business was going out of business so i can store most of my hand held tools out of the way and behind closed doors. Quote Link to comment Share on other sites More sharing options...
Kepy Posted August 9, 2009 Report Share Posted August 9, 2009 I have a bench made from a kit about 30 yrs ago, a 6' heavy metal table, a 6' folding table, 6' glue up table, drawing table and desk in the shop. I also use an old horizontal file cabinet that is for the router. I still don't seem to have enough table space. Quote Link to comment Share on other sites More sharing options...
Barry5180 Posted August 10, 2009 Report Share Posted August 10, 2009 I've got a homebuilt stand for my scrollsaw made from 2x4's and 3/4" plywood. Nothing fancy but it works. Building another such stand for my lathe. Then I have an old teacher's desk from a school that I have a computer on for pattern making and such. I use saw horses and plywood for most other shop activities as I'm working in a very limited space. Barry Quote Link to comment Share on other sites More sharing options...
greasemonkeyredneck Posted August 10, 2009 Report Share Posted August 10, 2009 I use anything I can get my hands on for a table. My main work table consists of a kitchen table I saved from a family member's garbage that had been left outside to give it a warped top, a door screwed down to that for flatness, and some MDF on top of that for a clean, renewable, surface. My paint, catchall table beside the work table is a door on top of sawhorses. I do have several work benches littered around the shop with different tools on them. A few weeks ago, the school threw away a 48" x 10' (feet) table that used to be in their computer lab. I saved it from the dumpster. You got me to thinking. With all this table top area, why do I have to clear a work area every time I work on a project? Strange. Quote Link to comment Share on other sites More sharing options...
Dan Posted August 11, 2009 Report Share Posted August 11, 2009 I built a 3' x 6' table from two-by-fours that was meant for doing sanding and finishing of my scroll work. But my father-in-law gave me a lathe and the bench was the prefect size for it. So now I'm back to using what little space I can find, including an old typewriter table. My wife told me to build another bench after I moved some tools into the basement. Quote Link to comment Share on other sites More sharing options...
