  I bought an 'easy lift'  mechanism to hold the saw up when changing blades.  You will have seen them around, - the one with the spring, for use with the DeWalt 788
I could not get the thing to stay balanced, in part, because I have the, (heavy) lamp that came with the saw, deal.
Being frustrated with that, I decided to make my own, and since I do not like to permanently attach things to my equipment, (in case of voiding repair warranties etc.)  I came up with this idea from just a piece of walnut scrap, and an unused hasp from a shed door padlock.
The pics should be pretty well self explanatory, but for clarity; I attached my "Saw Lift" with two electrical ties, and in the pictures, you will see that I have set in a small rare earth magnet, which has enough magnetic attraction to hold the 'lift' to the upper arm when not in use.  I also glued on  a small piece to prevent the 'lift' from going past vertical and letting the arm drop dpost-22561-0-55600000-1401899295_thumb.jpgpost-22561-0-45079000-1401899312_thumb.jpgpost-22561-0-46280100-1401899329_thumb.jpgpost-22561-0-89436800-1401899343_thumb.jpgown.
Looks good . If it works for you that's all that's matters. I still use the old 2X4. I have it chained to the side of my stand, with in easy reach and I don't loose it now I use it chained. I would rather spend the $30 on wood.
  Where did my reply go to???
I answered Ike, (so I thought,) then I appear to have lost it, ;o(   to say that yep, I did shell out $30. bucks for a lifter that didn't work out for me, - before coming up with a $2.95 outlay and a bit of thinking, to make something that works for me.
