CHIPPING THE RUST OFF
amazingkevin
HERE'S ONE FOR MY PHARMASIST TO DISPLAY AND ANOTHER OF TWENTY SAYINGS PLACUES  DONE,THIS ONE TOOK AN HOUR AS I USED A CORSER BLADE BUT THEN THAT CAUSED A ACCIDENT IN THE BOTTOM MIDDLE ,THE ONECURLY QUE DISAPPEARED SO I BALANCED IT OUT SCROLL REVERSE #12 FOR THE OUTSDE AND SOME INSIDE BUT THEN HAD TO SWITCH TO A #5 SCROLLREVERSE.tHE BLACK SIGN WAS DONE WITH A SCROLL REVERSE#3 THAT ONES ABOUT 6.5 INCH LONG 4"TALL I DIDN'T KEEP TIME ON THIS ONE.post-1607-0-42947400-1403284239_thumb.jpgpost-1607-0-09895000-1403284267_thumb.jpgpost-1607-0-10169600-1403284298_thumb.jpg
HERE'S ONE FOR MY PHARMASIST TO DISPLAY AND ANOTHER OF TWENTY SAYINGS PLACUES  DONE,THIS ONE TOOK AN HOUR AS I USED A CORSER BLADE BUT THEN THAT CAUSED A ACCIDENT IN THE BOTTOM MIDDLE ,THE ONECURLY QUE DISAPPEARED SO I BALANCED IT OUT SCROLL REVERSE #12 FOR THE OUTSDE AND SOME INSIDE BUT THEN HAD TO SWITCH TO A #5 SCROLLREVERSE.tHE BLACK SIGN WAS DONE WITH A SCROLL REVERSE#3 THAT ONES ABOUT 6.5 INCH LONG 4"TALL I DIDN'T KEEP TIME ON THIS ONE.attachicon.gif003.jpgattachicon.gif005.jpgattachicon.gif006.jpg
Definitely no rust there Kevin. Have you been using WD40????. Superb job. :thumbs:  :thumbs:  :thumbs:  :thumbs: .
Rob Roy.
Edited by Rob Roy
Thanks ROLY,It was to much trouble to rout a groove in some pine blocks for the little people and i made a jig with two clamps and a stick to rout them with instead of unloading the shelve and take down one of two router tables to do the job.it worked but could have been a nightmare of an accident. I
ll work on setting one table up for this as i did alot of little people before so the need is there. :)
