DWSUDEKUM Posted July 24, 2014 Report Posted July 24, 2014 This is a Steve Good Pattern and it is about 14 inches tall. The corian I used was a sink cutout from a kitchen install. The corian is 1/2 inches thick. I used a #9 ultra Reverse blade to cut the pattern. DW heppnerguy and amazingkevin 2 Quote
Clayton717 Posted July 24, 2014 Report Posted July 24, 2014 that looks pretty cool. I've turned corian but haven't cut any on the scroll saw. Any problems when cutting, did it heat up and stick back together? Quote
DWSUDEKUM Posted July 24, 2014 Author Report Posted July 24, 2014 that looks pretty cool. I've turned corian but haven't cut any on the scroll saw. Any problems when cutting, did it heat up and stick back together? It will tend to do that IF you use a small number blade. I used a #9 UltraReverse however a skip tooth generally will make a cleaner cut as the chips are able to get out of the kerf better. DW Clayton717 1 Quote
Fish Posted July 24, 2014 Report Posted July 24, 2014 Great work, I saw the pattern also, he has some great patterns. Thanks for sharing. Quote
heppnerguy Posted July 24, 2014 Report Posted July 24, 2014 A brand new pattern, cut from a rarely used material and done in the expertise expected from you posts. You out did even yourself and that is hard to do for anyone Dick heppenrguy DWSUDEKUM 1 Quote
Phantom Scroller Posted July 24, 2014 Report Posted July 24, 2014 It's a good cut DW as per Clayton I've only turned corian don't know where to find larger pieces. Roly Quote
DWSUDEKUM Posted July 24, 2014 Author Report Posted July 24, 2014 It's a good cut DW as per Clayton I've only turned corian don't know where to find larger pieces. Roly I have found corian in a couple of places. A lot of time you can find scrap pieces - generally pieces smaller than a foot square generally - from places that install kitchens. I also have found a good amount on Ebay. DW Phantom Scroller 1 Quote
lawson56 Posted July 24, 2014 Report Posted July 24, 2014 Never used Corian.Always shied away from it.used plexiglass though.Love your Panther cutting Fantastic job. :thumbs: Quote
amazingkevin Posted July 24, 2014 Report Posted July 24, 2014 Corian has a desirable lovely smell to it cut away on it.But it's hazardous to your health .Beautiful cutting DW. Quote
ike Posted July 24, 2014 Report Posted July 24, 2014 I have never tried Corian, I herd it is a hazardous material. I now use a a mask that is for asbestos so it would probably be ok. IKE Quote
robbert100 Posted July 24, 2014 Report Posted July 24, 2014 that came out great nice jod on this one Quote
frankorona Posted July 24, 2014 Report Posted July 24, 2014 Great and wonderful work, thanks for sharing. Quote
DWSUDEKUM Posted July 24, 2014 Author Report Posted July 24, 2014 I have never tried Corian, I herd it is a hazardous material. I now use a a mask that is for asbestos so it would probably be ok. IKE Like ANYTHING you cut you should not breathe the dust. Corian is a plastic and can give off a very fine talcum powder like dust as well as vapors that some folks are sensitive to when cut with a scroll saw. Wearing of a mask is and should be standard practice although a lot of us do not do so. Making sure that you have adequate ventilation is important as well. Cutting corian is really not more dangerous than cutting MDF or pressure treated lumber both of which are far more harmful to work with than corian. Corian is not difficult to work with it cuts easier than say oak. It sands easily and depending upon the finish you plan to use you can often stop sanding at around 400 grit. Corian will require buffing to bring up the shine of the plastic but that is easily done as well. DW Quote
smitty0312 Posted July 24, 2014 Report Posted July 24, 2014 I love the look of it....alot! Where do you buy your corian DW? Quote
