Hi could anybody advise me on the best blade to use to make 3D puzzels , like the lizzard puzzel on www philex3d.com
as there is no waste to saw into to do the sharp turns, all is seen. I use Mikes FD UR blades right now
Best Regards  Roy Ames, Manchester UK
Most any 2/0 blades work well,try a sample to see if they will work for your application.Young kids puzzles require thicker blades so the pieces go together very easy for little hands.I used the 2/0 puzzle blade for the steve good dollar bill puzzle and it worked good for the 1/8" wood the dollar was glued to.One thing to make sure of with puzzles is making absolutely certain the blade is running a true 90 degree's square to the saw table.If not the pieces won't go together easy or at all. :cool:
