DWSUDEKUM Posted August 12, 2014 Report Posted August 12, 2014 Cut from .022 inch brass plate. The plates are 1 inch high and 4 inches long. Cut with a #3 jewlers blade. DW Rob Roy, Fab4, lawson56 and 2 others 5 Quote
LarryEA Posted August 13, 2014 Report Posted August 13, 2014 DW thats professionaly done. Very nice. What are your plans for them and where would they go and be attached? Quote
DWSUDEKUM Posted August 13, 2014 Author Report Posted August 13, 2014 (edited) Larry the nameplates go on 10 Piggy Banks that are almost completed. They will reside beside the coin slot on top. They will be held on by 2 screws just like the windows for the bank. I got the order for the banks w/ nameplates from a grandmother for all of her grandchildren. I will post the order when it is completed. DW Edited August 13, 2014 by DWSUDEKUM Quote
Ron Johnson Posted August 13, 2014 Report Posted August 13, 2014 Yes, very professionally done DW. Excellent work. Quote
amazingkevin Posted August 13, 2014 Report Posted August 13, 2014 That is the best metal cutting i have ever seen!Did you break any blade?You put a CNC machine to shame!Did you make a jig to hold each name separately?Did you make any scrap.I am highly impressed with your skills here!!!!! :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: Quote
DWSUDEKUM Posted August 13, 2014 Author Report Posted August 13, 2014 That is the best metal cutting i have ever seen!Did you break any blade?You put a CNC machine to shame!Did you make a jig to hold each name separately?Did you make any scrap.I am highly impressed with your skills here!!!!! :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: Kevin I broke a dozen blades making those. No jig was used other than a zero clearance insert to support the letters as they were cut. I did not waste any either. I set my saw ( DW788 ) about 4 on the tension and about 4 on the speed and took my time. The reason most of the blades broke is I got impatient a time or three. I had my magnifying headset on of course. Not really all that hard, just a bit of practice. DW wombatie and amazingkevin 2 Quote
wombatie Posted August 13, 2014 Report Posted August 13, 2014 I take my hat off to you DW, everything you make looks 100% professional. Marg Quote
Phantom Scroller Posted August 13, 2014 Report Posted August 13, 2014 I've never cut metal on a scrollsaw so DW excellent work. Roly Quote
amazingkevin Posted August 13, 2014 Report Posted August 13, 2014 The best of the best that's DW! :thumbs: :thumbs: :thumbs: :thumbs: Quote
frankorona Posted August 13, 2014 Report Posted August 13, 2014 Excellent work great hold upon the cuts, thanks for sharing. Quote
scrollworks Posted August 13, 2014 Report Posted August 13, 2014 Excellent work DW. Takes a lot of patience to cut metal on the scroll saw. Very well done. :thumbs: :thumbs: amazingkevin 1 Quote
smitty0312 Posted August 13, 2014 Report Posted August 13, 2014 Very very nice DW, looks very professional like others have mentioned. Quote
Wilson's Woodworking Posted August 13, 2014 Report Posted August 13, 2014 Great job on the name plates!!! I will look forward to seeing the final product. Quote
Rob Roy Posted August 13, 2014 Report Posted August 13, 2014 Kevin I broke a dozen blades making those. No jig was used other than a zero clearance insert to support the letters as they were cut. I did not waste any either. I set my saw ( DW788 ) about 4 on the tension and about 4 on the speed and took my time. The reason most of the blades broke is I got impatient a time or three. I had my magnifying headset on of course. Not really all that hard, just a bit of practice. DW You've done a superb job on those DW, you should be proud of them, very professional. You may have lost a dozen blades but not your patience. An admirable job. Rob Roy. Quote
gator Posted August 13, 2014 Report Posted August 13, 2014 well everyone said whaat i wanted to say so i will add WOW WOW!!! where you get the brass? Quote
DWSUDEKUM Posted August 13, 2014 Author Report Posted August 13, 2014 well everyone said whaat i wanted to say so i will add WOW WOW!!! where you get the brass? Gator I got the brass sheet from Hobby Lobby here in Ohio. I do not know if they have one in your area however the major craft stores such as Michaels or one of those should have it, otherwise you can get it online. DW Quote
