The technique for the transfers is easy! Doing it is tricky.
Buy/beg/ borrow/ or "appropriate" as needed for the project some computer print labels of some kind.
(I bought CHEAP cd labels)---
Peel the labels off one sheet at a time as you need the sheet. Throw the labels away or ???
Open your favorite photo program -- edit-- size-- etc. your image-
when happy with image-----
Use flip horizontal so it turns out backwards---Some programs call this T-Shirt mode--
Print on the shiny side of your backing paper--THE SAME SIDE the labels had been on!
NOW TRICKY part
Very carefully pick paper off printer-- CAREFUL not to touch IMAGE!
Put some tap on edges
Lay VERY CAREFULLY of the wood-- TAPE FIRMLY DOWN
Now press over entire image! I actually used a finger and just went over it like I would have contact paper-- BEING EXTREMELY CAREFUL not to let it move at all
Now give it a little time --- GO HAVE LUNCH ?? When you are sure it is dry; you can clear coat it--spray polyurethane works well--- MAY BE other things that do too.
Practice on piece that can be re-sanded or thrown away.
Good Luck! I did find this technique on this site I believe-- SO I CAN not take credit for the idea! But, it does work!
The technique for the transfers is easy! Doing it is tricky.Buy/beg/ borrow/ or "appropriate" as needed for the project some computer print labels of some kind.(I bought CHEAP cd labels)---Peel the labels off one sheet at a time as you need the sheet. Throw the labels away or ???Open your favorite photo program -- edit-- size-- etc. your image-when happy with image-----Use flip horizontal so it turns out backwards---Some programs call this T-Shirt mode--Print on the shiny side of your backing paper--THE SAME SIDE the labels had been on!NOW TRICKY partVery carefully pick paper off printer-- CAREFUL not to touch IMAGE!Put some tap on edgesLay VERY CAREFULLY of the wood-- TAPE FIRMLY DOWNNow press over entire image! I actually used a finger and just went over it like I would have contact paper-- BEING EXTREMELY CAREFUL not to let it move at allNow give it a little time --- GO HAVE LUNCH ?? When you are sure it is dry; you can clear coat it--spray polyurethane works well--- MAY BE other things that do too.Practice on piece that can be re-sanded or thrown away.Good Luck! I did find this technique on this site I believe-- SO I CAN not take credit for the idea! But, it does work!
that's a great tip, I have used before and works fine, agree with the comment of not touching the printed label
