edward Posted August 17, 2014 Report Posted August 17, 2014 On my Dewalt the air hose is loose where the plastic meets the ball, does anyone have any ideas how to fix this. thanks edward Quote
MrsN Posted August 17, 2014 Report Posted August 17, 2014 I have 2 dewalts in my school shop. Both have broken air hoses because high school kids got rough. I simply wrap electrical tape around to hold it to the post. It works pretty well as long as you are fairly careful with positioning the air hose, I end up re-taping it every couple of weeks. I sort of want to try heating up the plastic piece and then pressing it back on to the round post. something like boiling water that wouldn't melt the hose but make it slightly pliable. I haven't done it yet because I don't have a good way to get boiling water in the shop. LarryEA and smitty0312 2 Quote
browders Posted August 17, 2014 Report Posted August 17, 2014 My air hose cracked at the junction with the machine. I was able to remove that section and press the next section onto the fitting. I had to push pretty hard, but it's worked ok since. Quote
amazingkevin Posted August 17, 2014 Report Posted August 17, 2014 i wound and wound and wound rubber bands around my dw788 still working good Quote
rjR Posted August 17, 2014 Report Posted August 17, 2014 I used plan C! After separating the cracked segment, I carefully heated the next section with a heat gun--(Like a hair dryer-- just designed for heat--H-F special) let it get semi-fluid--- shoved it over and used a plier to crimp it down- needle nose and on saw side of knob--(it was hot enough to burn fingers)-- has worked well ever since and that is a few years ago already!) I had forgotten about it until this post. I had tried the tape and rubber bands thing and it did not work well! This took longer-- better results. Phantom Scroller 1 Quote
sawdust1 Posted August 17, 2014 Report Posted August 17, 2014 Use a small hose clamp, works great. Bob NC Scroller 1 Quote
JustLarry Posted August 18, 2014 Report Posted August 18, 2014 Also used hair dryer to heat up connection and pushed it together. If in need of a new hose and you do not want to spend $20.00 for the DeWalt replacement you may want to give a look at these: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=oil+water+flexible+coolant+pipe&rh=i%3Aaps%2Ck%3Aoil+water+flexible+coolant+pipe Larry ann and barb.j.enders 2 Quote
amazingkevin Posted August 18, 2014 Report Posted August 18, 2014 Wow Larry those are really neet, good find Quote
ike Posted August 18, 2014 Report Posted August 18, 2014 I worked in a machine shop ant there is a tool that works very well , and there is extra links for this if that interest you try granger of MSM they have it. at least when was working, Quote
DWSUDEKUM Posted August 18, 2014 Report Posted August 18, 2014 I have 2 dewalts in my school shop. Both have broken air hoses because high school kids got rough. I simply wrap electrical tape around to hold it to the post. It works pretty well as long as you are fairly careful with positioning the air hose, I end up re-taping it every couple of weeks. I sort of want to try heating up the plastic piece and then pressing it back on to the round post. something like boiling water that wouldn't melt the hose but make it slightly pliable. I haven't done it yet because I don't have a good way to get boiling water in the shop. A hair dryer should work well for that. Quote
Kragax Posted August 18, 2014 Report Posted August 18, 2014 Those tubes from Amazon look great. I solved most of my dust problem by using the end of a ball point pen to neck down the tube from the pump, but Im going to order one of these. I have the tube mounted on a clothes hangar wire and its a pain. Quote
Wilson's Woodworking Posted August 18, 2014 Report Posted August 18, 2014 I worked in a machine shop ant there is a tool that works very well , and there is extra links for this if that interest you try granger of MSM they have it. at least when was working, I think this is what you are talking about Ike. I keep a pair in my tool box at work all the time. It is a lot easier than snapping them together by hand. http://www.mscdirect.com/product/details/09777020 Here is a link for loc line if anyone needs it but you can probably find them cheaper on eBay. http://www.mscdirect.com/browse/Coolant-System-Hose-Nozzles-Accessories?navid=4294719525+12107422&searchterm=Loc-Line Quote
Doug Posted August 18, 2014 Report Posted August 18, 2014 This link is to the manufacturer of what Larry took you to on Amazon http://www.modularhose.com/Loc-Line-14-System and if you ever get frustrated enough with trying to assemble two pieces of Loc-Line, get their special tool - it avoids much frustration and language you do not what your grandchildren to hear http://www.modularhose.com/Loc-Line-14-System/14-miscellaneous If you ever need to hook the Loc-Line to the metal under the upper arm where the bellows is, take the metal piece off the upper arm to use the Loc-line tool. You do not want to know how long it took me to find a simple way to do this or why I even needed to do this. Wilson's Woodworking 1 Quote
edward Posted August 18, 2014 Author Report Posted August 18, 2014 I put a hose clamp over it like Bob said, and seems to work. Thanks edward Quote
Doug Posted August 18, 2014 Report Posted August 18, 2014 I think this is what you are talking about Ike. I keep a pair in my tool box at work all the time. It is a lot easier than snapping them together by hand. http://www.mscdirect.com/product/details/09777020 Here is a link for loc line if anyone needs it but you can probably find them cheaper on eBay. http://www.mscdirect.com/browse/Coolant-System-Hose-Nozzles-Accessories?navid=4294719525+12107422&searchterm=Loc-Line Danny We must have been typing at the same time - it just took me longer to get the links and click on "post". Wilson's Woodworking 1 Quote
Fish Posted August 18, 2014 Report Posted August 18, 2014 When mine broke on my first saw I used an aquarium air pump and some plastic tubing and a short piece of 1/4" copper tubing. Worked fine. I still have it as a backup. Quote
heppnerguy Posted August 18, 2014 Report Posted August 18, 2014 If the link attaching it to the machine is cracked then i would throw it away. One less link is not a big deal. I had mine pulled off by my grandson messing with my saw when I was not there. Is just pushes back on. it is very difficult to do but that is how they are put on. I finally boiled mine in a pan of water and then after it was hot I laid my machine on it's side and was able to push it back on. The heat gun or hair dryer suggestion looks like maybe an even better idea than mine, the heating up of the link is for expansion purposes. It is never easy to get back on but that is what they do at the DeWalt repair shop. Push really hard....no I said REALLY HARD... there even though you did not think it would work, it did Dick heppnerguy Wilson's Woodworking 1 Quote
Wilson's Woodworking Posted August 19, 2014 Report Posted August 19, 2014 If the link attaching it to the machine is cracked then i would throw it away. One less link is not a big deal. I had mine pulled off by my grandson messing with my saw when I was not there. Is just pushes back on. it is very difficult to do but that is how they are put on. I finally boiled mine in a pan of water and then after it was hot I laid my machine on it's side and was able to push it back on. The heat gun or hair dryer suggestion looks like maybe an even better idea than mine, the heating up of the link is for expansion purposes. It is never easy to get back on but that is what they do at the DeWalt repair shop. Push really hard....no I said REALLY HARD... there even though you did not think it would work, it did Dick heppnerguy Let’s hope they have the right tool for the right job at DeWalt. I can't imagine having to snap hundreds of those together in a day without my pliers that are designed to do the job. My fingers would wear out after just a few. Quote
Joe W. Posted January 28, 2021 Report Posted January 28, 2021 On 8/17/2014 at 3:30 PM, browders said: My air hose cracked at the junction with the machine. I was able to remove that section and press the next section onto the fitting. I had to push pretty hard, but it's worked ok since. I had the same thing with my scroll saw. First I tried JB Weld epoxy and soaking it in boiling water and then pushing the end onto the bellows output metal on the side - didn't work. I pushed so hard on the end of the air hose the small crack got bigger to the point where I decided to pull that piece off. Surprisingly, it easily separated from the rest of the air hose. With the end of the air hose still hot from the boiling water, I pushed the end of the air hose onto the bellows output and it went on easily with a little bit of force. Off to a good start for the day! Quote
barb.j.enders Posted January 28, 2021 Report Posted January 28, 2021 I used a hair dryer to warm the next joint in the hose, pushed it on to the machine. I believe Steve Good did a demo on this. Quote
