amazingkevin Posted August 21, 2014 Report Posted August 21, 2014 (edited) 3/4 plywood #7 scroll reverse blade,10" tall and stained This is a THESCROLLSAWARTIST.COM pattern,SUE MEY Edited August 25, 2014 by amazingkevin bobman58 and keefie 2 Quote
NC Scroller Posted August 21, 2014 Report Posted August 21, 2014 Nice cutting. How you planning to finish it? Quote
amazingkevin Posted August 21, 2014 Author Report Posted August 21, 2014 Hi Scott, I'm dying to try watering down food coloring, but found out that a Tupperware container with lots of stain in speeds up the staining process immensely by soaking the project in it rather than splash and scrub and dab, etc the stain to get everything covered. Then i pour it back in the can.I used to get extra wide rolls of aluminum cooking foil and make a little tray under and around the project and pour in the stain, then tilt it up and poke a hole in the foil and drain it back in the can .Works for me great with fret work ,you don't miss a spot that way. Pat W. 1 Quote
DWSUDEKUM Posted August 21, 2014 Report Posted August 21, 2014 Very nicely done Kevin. What font is that? Thanks for sharing this with us. DW Quote
DWSUDEKUM Posted August 21, 2014 Report Posted August 21, 2014 Hi Scott, I'm dying to try watering down food coloring, but found out that a Tupperware container with lots of stain in speeds up the staining process immensely by soaking the project in it rather than splash and scrub and dab, etc the stain to get everything covered. Then i pour it back in the can.I used to get extra wide rolls of aluminum cooking foil and make a little tray under and around the project and pour in the stain, then tilt it up and poke a hole in the foil and drain it back in the can .Works for me great with fret work ,you don't miss a spot that way. Kevin take that food coloring and add it to denatured alcohol you get the staining but no grain lifting. Works good and is pretty fast. DW amazingkevin and LarryEA 2 Quote
amazingkevin Posted August 21, 2014 Author Report Posted August 21, 2014 Soon as some money comes in i'll do that that's!I had every thinner but lost everything to many times Quote
LarryEA Posted August 22, 2014 Report Posted August 22, 2014 The fonts you choose are outstanding. One reason I enjoy reading your posts and others, there are frequently 'teachable' moments in them. In this one there are two for me. Food coloring in a pan and using denatured alcohol. And in case you did not read betwen the lines... I like your Bible verse very much. Larry Quote
heppnerguy Posted August 22, 2014 Report Posted August 22, 2014 Kevin, I like everything about this one. I like the plaque design, the composition, the message and the font you used.. What is the name of that font ? I have been looking for it for a long time Dick heppnerguy Quote
Bendita Posted August 22, 2014 Report Posted August 22, 2014 Gimmee An A gimmee a M Gimmee An A O you know where Im going with this just utterly Amazing work Kevin its looks soft and comforting great message and job LarryEA 1 Quote
amazingkevin Posted August 22, 2014 Author Report Posted August 22, 2014 (edited) .But this is an easy one i've done over and over again as it's a good seller.This amazing piece is inTHESCROLLSAWARTIST.COM site under plaques or religious . Edited August 25, 2014 by amazingkevin Quote
amazingkevin Posted August 22, 2014 Author Report Posted August 22, 2014 Dick i thank you ,It's a very easy one to cut and in less than an hour With a scroll reverse#3 on the Dewalt speed of 5. I now spray the glue on the back of the pattern ,let tack then press on .This way there is lots less glue on the project, it's self. I knew this before, but absence from scrolling you forget the tricks you use everyday.this one is in 3/4" spruce stain grade .It comes wrapped in clear plastic at the big box store ,lowes and the price is right ! They come in 6'-8'-10' and maybe 12'lenghts and 10"-12" and 16" widths.I save all the scrap for little people stands mostly.I need to set of a third router table just for cutting the slot in the oval scraps that i stick the little people in with glue.The older i get now all the walking and project steps i can save makes for more enjoyable scrolling quality time.I wish i could wear headphones to listen to my religious station .but then i won't here the phone. Quote
wombatie Posted August 22, 2014 Report Posted August 22, 2014 This one is perfect Kevin just perfect. Marg Quote
lawson56 Posted August 22, 2014 Report Posted August 22, 2014 Just Fantastic Kevin.Needs to be in a Church. :thumbs: Quote
frankorona Posted August 22, 2014 Report Posted August 22, 2014 Wonderful work Kevin, thanks for sharing. Quote
bobscroll Posted August 22, 2014 Report Posted August 22, 2014 You did a really good job on this project Kevin, Thanks for showing, Bob Quote
robbert100 Posted August 22, 2014 Report Posted August 22, 2014 nice work i realy like the wood choice Quote
amazingkevin Posted August 23, 2014 Author Report Posted August 23, 2014 Thanks Bobby ,I've left plenty in churches and even churches I've never been in! Quote
