summertime Posted August 25, 2014 Report Posted August 25, 2014 Hi , the top arm on my EX 30 wont stay up when I lift it like it used to do, saw still works, I have not moved the tension knob. I try to keep the gap at the back of the arm the same as the front to minimise the front to back movement of the blade. Anyone got any Idea what has gone wrong or moved? ROY Manchester UK Quote
Doug Posted August 25, 2014 Report Posted August 25, 2014 (edited) Check your manual. At the back on the left hand side as you are sitting in front of it you will find a bolt sticking out which has a screwdriver slot in it and a nut which holds the bolt in place - loosen the nut, give the bolt a quarter turn, tighten the nut and test the adjustment to see if it needs tightened more or whether it is too tight. I am assuming the 30 has the same arm tension adjustment as the 21 but I am away from my saw and manual so am just relating what I do on the 21. It is a friction type of thing so over time it naturally has some wear and will not hold the arm up as well. Edited August 25, 2014 by Doug Lucky2 and Nick@tinkers-cove 2 Quote
Nick@tinkers-cove Posted August 25, 2014 Report Posted August 25, 2014 (edited) Hey Roy. There is a screw that needs some attention on the left hand rear panel. It only needs to be tightened slightly. I don't have the full details right now, but if you send me a message directly, stating your email address, I'll send you the EX 30 user manual. Hope this helps. Kindest Regards, Nick - Bridlington (East Riding of Yorkshire) Love Manchester by the way...especially over the Snake Pass to Glossop. Edited August 25, 2014 by Nick@tinkers-cove Quote
summertime Posted August 25, 2014 Author Report Posted August 25, 2014 Hi Thanks everyone for your help, done what you told me, worked a treat, bought off E bay, never got the manual sent on as prommised. thanks again, thought something had broken inside, a bitr sick. OK now thanks Roy Quote
Nick@tinkers-cove Posted August 25, 2014 Report Posted August 25, 2014 Let me know if you ever need a PDF of the manual, Roy. Quote
Doug Posted August 25, 2014 Report Posted August 25, 2014 Roy Click on the link and then click on Manual so you have what you need. http://www.general.ca/products/2_excalibur/EX-30.html Quote
Doug Posted August 25, 2014 Report Posted August 25, 2014 Let me know if you ever need a PDF of the manual, Roy. Nick When I started typing your post was not up yet or I would not have duplicated it. Must have just taken yours longer to cross from UK. Nick@tinkers-cove 1 Quote
summertime Posted August 25, 2014 Author Report Posted August 25, 2014 Thanks doug, Its apitty that Seyco dont have a branch over here for advice and their special upgrade bits and pieces. Thanks again Roy Quote
Nick@tinkers-cove Posted August 25, 2014 Report Posted August 25, 2014 Nick When I started typing your post was not up yet or I would not have duplicated it. Must have just taken yours longer to cross from UK. Good old fibre optic, eh Doug! Maybe it's time to jump back to morse code LOL Phantom Scroller 1 Quote
amazingkevin Posted August 26, 2014 Report Posted August 26, 2014 What a great place SSV,coffee ,mechanics,pattern makers Nick@tinkers-cove 1 Quote
Phantom Scroller Posted August 26, 2014 Report Posted August 26, 2014 (edited) Nick my Commadore VIC20 works ok. Edited August 26, 2014 by Phantom Scroller Quote
