dansnow Posted August 31, 2014 Report Posted August 31, 2014 (edited) I will occasionally google images of one thing or another to get ideas for our inventory. While looking at puzzles I saw a photograph of a couple that looked folk art-ish enough. Played around with a pencil and a copier for a bit and came up with these two. On the train I realized as soon as I cut the cab section that I was going to have to redesign the joint because the original is way too fragile. I was able to reinforce the piece, but subsequent pieces (if they sell) will be better designed. Edited September 1, 2014 by dansnow lawson56, bobscroll, keefie and 1 other 4 Quote
LarryEA Posted August 31, 2014 Report Posted August 31, 2014 I really like the train engine and the tractor is pretty nice too. Quote
Phantom Scroller Posted August 31, 2014 Report Posted August 31, 2014 Both good puzzles Dan. Roly Quote
amazingkevin Posted August 31, 2014 Report Posted August 31, 2014 They look challenging ,nice finished project,happy sales! Quote
DWSUDEKUM Posted September 1, 2014 Report Posted September 1, 2014 Nicely done Dan. Thanks for sharing these with us. DW Quote
lawson56 Posted September 1, 2014 Report Posted September 1, 2014 I'm a Big Train guy.Love that one.Tractor will do good in my area.Great puzzles. :thumbs: Quote
frankorona Posted September 1, 2014 Report Posted September 1, 2014 Wonderful work Dan, thanks for sharing. Quote
edward Posted September 1, 2014 Report Posted September 1, 2014 Both Puzzles look great, nice job on the cutting. edward Quote
bobscroll Posted September 1, 2014 Report Posted September 1, 2014 Dan, They do look good! Thank you for showing, Bob Quote
dansnow Posted September 1, 2014 Author Report Posted September 1, 2014 Thanks Guys! I had to recut the train. The cab piece I was worried about cracked while sanding. No biggee, It only takes about 15 minutes to cut out of 3/4" pine with a 5PGR blade. The pieces were redesigned to eliminate thin sections. Quote
keefie Posted September 1, 2014 Report Posted September 1, 2014 Dan they both look great, but love the train, any chance you want to share the pattern for the train? Quote
dansnow Posted September 1, 2014 Author Report Posted September 1, 2014 Don't have a pattern per se, I googled train puzzles, found this one, saved and printed the picture actual size, then copied it at 115% If you want to PM me a street address I can mail you a print that I use. When cutting, depending on the tightness of the grain of the wood I'm using, I'll make some of the small tabs thicker to give them more strength. Quote
