I started this about one year ago then it sat until last month. I took a picture of the hawk in my brother's backyard, converted it to a pattern, then put it on wood. The wood is cherry. The flaw is a knot that was originally in the board. It's finished with satin polyurethane. I did torch the edges to give is some sort of framing. Most of it was cut with a FD-#1UR and some with a #1 spiral. I did notice some fading of the wood after I removed the pattern. Learned a lesson there.
If I remember correctly. you showed us the photo and the process that you took to make the pattern. It came out very nice. It was definately worth the wait.
Dick
heppnerguy
Thanks everyone. I put the pattern on last year and every part that was uncovered got a sunbath. Hehe.
Dick, I think I did post the photo then the pattern. If I were to use the oattern again I would not cut the area below the tail.
