jwbright1984 Posted September 18, 2014 Report Posted September 18, 2014 I'm finally got to make some saw dust. These are my first two patterns to cut out so I'm very very new. I have learn a lot by these two cuts. I would like for y'all to tell me what I need to do different and any tips or tricks would be wonderful. The deer was my first and I can see a lot of places I messed up and the 1/4 birch plywood is not a good grade so it started chipping and breaking so I didn't cut the pattern exactly the way it should have been but I thank bigdogskitten11 for the pattern. The duck was my second one and it went a lot smoother because I learn so much from the deer. And I apologize but I can't remember where I got the duck picture from but thank you to whomever was the designer. So tell me where I need to do better. I have ALOT of improvement needed so don't be easy on me!!!! Haha. Thank y'all for your time. bobscroll and robbert100 2 Quote
Scrappile Posted September 18, 2014 Report Posted September 18, 2014 very good start. I can't give you advice, I'm just learning also. Well I can pass on two pieces of advice that were given me and really helpful to me. 1 - take a deeo breath before starting to to cut and then concentrate on breathing normally. 2 - Lower your shoulders don't have then raised up around your ears. Simple advice, but really helped me. The main thing this advice was telling me was to relax. Another thing I have done in buy many sizes and types of blades from Mike's Workshop and I have been experimenting with them to determine which ones work best for me on different types of cuts. Between the deer and the duck you can already see improvement, so practice, practice. I'm accumulating quite a pile of practice cuttings. I wish I would have numbered them so I could see if I am improving. Quote
Bendita Posted September 18, 2014 Report Posted September 18, 2014 Well Wesley your deer picture is wonderful for a first attempt All though hard to see but it appears you used a spiral blade for at least a part of the picture, no problem if the blade would have been in the right direction (pointing down) I see a lot of chip out on the top of the plywood indicating the upside down blade, you had some difficulty turning when you used a straight blade but that all comes with practice overall I grade this as a A for effort, the duck on the other hand is excellent It appears to be cut with a straight blade and you did a fantastic job this my friend is a very sellable portrait no problem keep it up. As for plywood you're not going to get much better quality for scrolling then birch but when you buy it be selective don't settle for the top sheet on the pile. Good luck and keep the pictures coming. .../Hans LarryEA 1 Quote
LarryEA Posted September 18, 2014 Report Posted September 18, 2014 As Scrappy said, learn the blades that works best for you and the wood. As you have already realized, practice. We all make mistakes, the trick is learning to hide most of them. Consider using good plywood like Baltic Birch. Also when using solid wood be aware it can warp. And I like Sloans Woodshop also for blades. Quote
jwbright1984 Posted September 18, 2014 Author Report Posted September 18, 2014 Thanks for the kind words. I really appreciate that. I didn't use spiral blades but I plan on getting some. Now It is very possible that I had a blade upside down because I broke 6 or 7 blades on the deer. But as I got use to my saw I quit breaking blades and used the same one for the duck. I'm not real happy with my blades. I plan on getting a variety to see what I like better. And thanks again for all the advise. Quote
ike Posted September 18, 2014 Report Posted September 18, 2014 (edited) These are 2 very good starts. The duck is much better than the deer/ Just remember to take your time and it really helps if you keep your saw table waxed. I work with my DeWall speed at 6 for most projects. I like a #4 blade for plywood, and if I stack cut it seems to work better. and I never use box store blades, I have no luck with them. Edited September 18, 2014 by ike Quote
browders Posted September 18, 2014 Report Posted September 18, 2014 I think your work looks great. I too use a DeWalt and have never had a problem. Regarding blades, I agree with Ike on the blades. There are a couple of good sites which sell blades. You should by an assortment of brands and sizes and find the ones which work for you. Can't wait to see more pictures. Jim Quote
jwbright1984 Posted September 18, 2014 Author Report Posted September 18, 2014 Wow this is just simply awesome!!!! You guys rock! Not the first negative comment or anything. Just great advise from the experts!!!!! Thanks so much for all the info!!! I definitely gonna try new blades!!! Y'all make me feel like I done ok for my first cuts!!! browders 1 Quote
amazingkevin Posted September 19, 2014 Report Posted September 19, 2014 Mister Wesley,I'm proud of your gracious attempts in the first project.You started long runs and went from beginning to end without starting and stopping.Very good concentration!Your a Wizz on the turns ,you get in and out without burning the corners turning about faceA quality i lacked for quite a awhile,Your a born natural scroller from day one!1/4" wood i'd use a #3,#2,#1 or a#2/0 blade to avoid chipping the wood on thin stock.Looks like your fireing on all cylinders in the second picture.You learned fast and are scrolling with the best of them now.Good job.Don't miss a day here so many tips and tricks given out readily every day.Your the apple of our eye posting pictures so soon.A picture tells the whole story for us.Your also batting a 100 now with you new found hobby,glad you found us , you've made friends today ,more tomorrow,Welcome Quote
jwbright1984 Posted September 19, 2014 Author Report Posted September 19, 2014 Mr. Kevin that's very nice of you to say all that. I really appreciate those kind words and motivation. I have a lot to learn and thank each of you for all the info and advice. I learn something new Evertime I look at the forum. I'm enjoying every bit of it. I will post more pics soon. Quote
DWSUDEKUM Posted September 19, 2014 Report Posted September 19, 2014 Very very nicely cut. Thanks for sharing these with us. DW Quote
wombatie Posted September 19, 2014 Report Posted September 19, 2014 Wesley first let me congratulate you on a terrific start. The first one, the deer, apart from the ply your cutting seems OK. I bet once it was sanded it looked a lot better. The second one, the duck, no one could fault that, you did an excellent job. My only bits of advise are number one relax, if you find your shoulders up around your ears, go for a walk and then start again. Secondly, and this advise was given to me, is if you have a pattern that is slightly complicated, start with the hardest part first, that way if it breaks you have not wasted your time. Apart from that just practice, practice, practice. Marg Quote
lawson56 Posted September 19, 2014 Report Posted September 19, 2014 You have been given a lot of Great advise here.I was not as Lucky as you when I first started.Your off to a Great start.I can tell a big difference between the 2 cuts,Keep up the good work.Have plenty of Patience/Practice. Quote
bobscroll Posted September 19, 2014 Report Posted September 19, 2014 Hi Wesley, I too think you've got off to a great start, It is like riding a motorbike for the first time, You look just in front of it but as you learn to ride better you just look ahead of you and ride! Thank you for showing us your first cuttings, Bob Quote
frankorona Posted September 19, 2014 Report Posted September 19, 2014 Well, to be your first job is great, keep practicing. Quote
jwbright1984 Posted September 19, 2014 Author Report Posted September 19, 2014 Wow!!!!! Thank you thank you thank you!!!!! I have truly learned something from each of you!!! Y'all had a part in these cuts bc I had been searching the forum and post picking up info from everybody. Thank you again for the kind words Quote
Luperez548 Posted September 21, 2014 Report Posted September 21, 2014 Both of them are good projects, I fully agree with the rest of the comments. One trick I would add is that you need to be familiar with your pattern. I spend few minuted analyzing some patterns to determine the order of some intricate cuts and small weak bridges, it helps to avoid mistakes and broken parts. Also some times a keep the cut piece in the hole adding clear tape, this will support your structure while cutting the rest of the piece. Very good job, keep in the good work. PD. I do believe the duck is a Steve Good Pattern. Quote
