question ,, what do most people cut as far as wood and thickness go , when doing a portrait of people? ....
i have been using 1/4 inch Baltic birch with good success depending on the pattern, some times thicker wood but it has to be a stright forward pattern ,,,  but i just wanted to ask the question  .
When cutting Portraits I use oak Plywood I just like the grain Feature . I use oak when it calls for 1/4 thickness if I use plywood sometimes I use walnut or oak solid woods. For others I prefer 1/2 inch wood is my preference.
IKE
I don't cut a lot of portraits but when i do I usually cut with 1/8 or 1/4 inch BB ply. love to see some of your  work. any problems let us know because everyone can learn something new when someone give some information. Often I discover something I have never realized was even a problem for me until someone ask a question and another person gives them an answer. I find myself saying, "I didn't know that" , many times
Dick
heppnerguy
Hi, John,
I started using 1/4" Baltic Birch but, it became harder to find store bought frames that will accomodate the 1/4" so I
switched to 1/8". If it is not something that I can stack cut and have use for the extra portraits I just use some form
of scrap like old paneling to keep the 1/8" material from chipping.
God Bless! Spirithorse
I prefer the look of 1/8" BB ply, but cut 1/4" as well.  I don't think I would go much larger than 1/4", though.  If it's thicker, I think you lose some of the detail since the edge of the wood would cover the backer at certain angles (the backer really makes the portrait stand out so you can see the details).  The real trick with cutting 1/8" ply is to stack cut 2 or 3 pieces.  It gives you a lot more control over the blade.  Plus, you get 3 copies.  Even if you don't want the extra copies, I'd still stack cut just for the extra control.  It may seem wasteful, but the end product is well worth it.
