Kevin had requested the test results of my dustfree system . I decided to do a new post ,to high lite some new handy uses .
some related to strictly scrolling some not ,first of all a jitter bug sander  or a power carver .even a 4"grinder can be used in this set -up  ! simply put your choice in the cabinet slip the electric cord thru the flex sleeve and seal the draw string , allow the flying dust to be sucked out of the cabinet and the falling to settle  prior to reopening the top see thru lid ( this is  ONLY for pieces too large to turn inside the cabinet with out the extra room needed to flip or rotate your project ) I have sanded boards (that fit )inside the 29" W x 22" D cabinet with a jitterBug  electric sander ,air sanders not recomended ( for obious reasons )
vaccumn baffle may need adjusted completely closed in those cases . I lost this entire post because the site said I had to wait 13 sec to post ,I hope this goes through ,I followed the instructions and still lost the text, And I type very slow .any way ,here are some pictures taken with my new phone ,my old one jumped off my belt case and ran away and hid ,this one will need to figure a new escape plan as this case is full looped to my belt , I hope the pix are ledgeable ! Questions or critics welcome !!
Acording to the error warning as I attemped to post I lost both post's ,I posted ? to travis ,but mysteriously bothposts went thru one with pix one with out ,I have not heard back from travis ,but some how both got thru ,I am at a lose as to what went on ,thats the reason for two posts ! sorry for the glitch .
Very nicely done Carl.  Thanks for sharing this with us.  Like the idea... might need to make it bigger though to handle larger things... I use something like that but for spraying finishes in the winter time.
DW
Larry there is only one ,beside the tray there is a vac manafold as part of the under table cavity and set swing in swing out vac on top w/ mag lite and spot .
DW size is not a problem.  Space for it is depending on your available area , larger would only require y ing you vac.for the cavity size and space .
