Woods used: Yellow Cedar, White Pine, Bamboo, Mahogany, Baltic Birch
Metal used: .039 Brass
Cut from a block of Mahogany - 3/4 thick 1 1/2 wide.  Shellaced
Cut from 3/4 Yellow Cedar.  Sealed with tung oil and top coated with Shellac.
Cut from 1/2 in Bamboo and shellaced
Collapsible basket cut from white pine.  Shellaced.
Baltic Birch Tree topper - awaiting decision on how to finish it.
Cut from .039 brass - Cut for an Aunt to use as a coat zipper pull
Cut from 1/2 in. Bamboo flooring - Shellaced
DW
Edited by DWSUDEKUM
Great work, i'd love to see your bowl blanks before cutting. I've been wanting to glue up over 100 thin, long 3/32 strips to make a bowl blank to work from. will this be way to much glue to sand when that time comes. Just looking for pro's an con's before i tackle my first bowl,thanks,! :cool:the baby mini deer are outrageous! :cool:
Edited by amazingkevin
Great work, i'd love to see your bowl blanks before cutting. I've been wanting to glue up over 100 thin, long 3/32 strips to make a bowl blank to work from. will this be way to much glue to sand when that time comes. Just looking for pro's an con's before i tackle my first bowl,thanks,! :cool: the baby mini deer are outrageous! :cool:
Kevin use just enough glue to coat both sides of the strip clamp them let them cure.  It should not be much different than working with plywood.  Clean as you go would be the key here I would think.  The less glue outside of the joint the better.  The reindeer are actually a fast seller at my November shows.  Last year I sold 30 or so of them.  They can be hung by their antlers and be tree ornaments.
DW
DW
Beautiful work DW, you've been a  very busy man. By the sound of things there's more to come :D  :D  :D .
Rob Roy.
