about a week ago my dw 788 started to make funny noises and wouldn't cut  straight so I took it to the repair shop. They finally got it back to me today I am glad because it was still in warranty just barely. So I can go back cutting except the cold front is coming thru maybe I will get out and make something during the 44 * weather. I am now going to some auctions and get a back up saw. hind sight is 20/20
They didn't say. The Mechanic had already left for the day and the counter  didn't know so I guess I will never know. so I will recommend for every body to get a back up .
Edited by ike
I have three!Glad your still cookin,that's got to be tough to scroll in that kind of weather.Section of the scrolling room so you will need less heat  with sheet plastic from the big box stores.
Edited by amazingkevin
Been there---DONE THAT! When my hands locked up I had to go I ! Wore heavy boots and a [pair of insulated coveralls. There was no way to heat a tin garden shed-- especially at MINUS ZERO TEMPS! My drillpress howled-- I would turn it on and let it run BEFORE I tried to use it!
Forties was not too bad-- did not kill equipment like the extreme cold does!
I am so lucky. Went to my shop a few minutes ago.   20 degree F. but I have a woodstove in my shop. started the fire will return in a couple of minutes. Had a small fire in the stove yesterday, Outside it was 14 degrees. My workbench is close enough to the door that I can open and close it without leaving the my saw. I cut with the door partially open, yesterday.
Dick
heppnerguy
I like to be comfortable have a karosene heater and a/c in the wood shop, have space heater in a 2 car garage I use for auto work (ac also).  Considering puting another space heater in the wood shop as only 1 karosene dealer near me & he gets $6.00 per gal.
I guess nobody wants to know that I'm still scrolling wearing my shorts and a T shirt I don't even own a heater
Boy, that's for sure. We are finally warming up here. The temperature was 6 degrees above zero.
Not to be a smart a++ but when I take anything in for repair ,I tell them I want a detailed found ,fixed list when I pick it up along with the replaced parts ,not fool proof but does cut down on the shanagans ! Otherwise you are at their mercy ,and never know what they did ! Been around too many shops and heard some not so funny stories !
I ask but the woman at the desk didn't know and the mech. left early. There wasn't a charge on it due to warranty so I guess they
thought they didn't need to explain.
It's -4 (Celsius) here tonight, I think that is around 25 F. :cry:  A couple of years ago I sectioned off an 8 x 10 area of my garage for my workshop. Now I go out and turn on the heater and I can usually get it up to a comfortable 20 degrees (Celsius) inside :)
I went out Tuesday and did a little work( about 1 hour )then I was getting a little cold but I did finish up a nativity sine, this weekend it is to be up to 50f that is good working weather .
