Stack cutting.
wombatie
I have been stack cutting for years but I only just thought of this question.  (Ok I used to be blonde) :lol: :lol:   After I have finished stack cutting I always seem to spend a long time sanding the bottom piece.  Do any of you just cut an extra piece and  throw the bottom piece away or do you just do like I do and sand and sand and sand?
Marg
Marg, that is a good question.
I do sometimes place a sacrificial piece over my smaller items, sometimes top and bottom, as Master Scroller says using reverse tooth blades minimise problems. I often cut 4 or 5 at once and I find the top one with the glued on pattern the most difficult to salvage, I glue the pattern on and with delicate patterns it is difficult removing all traces of the pattern, normally I use a 6" wide belt sander to do this but it is a bit fierce.
Generally the bottom one is not so much a problem when using reverse teeth blades.
I rarely cut just one of an item unless I am using thick material. I always cut at least 2 often 3 even if I only need one, you then have a bonus if they all turn out. Often when I show my daughters something I have made they want one anyway!
Marg,
    Here is something that I do that used to scare me because I thought it would break my pieces but found it not to be the case. I use a random orbital sander with a 220 grit paper on it. After I cut my pieces I just sand them on both sides with my orbital sander and then i use a large stiff toothbrush, (one designed for  false teeth) and it all only takes a couple of minutes and does a great job of r me. If you are afraid of the sander breaking the wood, I want you to know that was how I took the fuzzies  off my Eiffel Tower and that was full of very small and frequent holes. it never broke a single hole. No burning, no hand sanding and no throwing away pieces.
Dick
heppnerguy
to remove my pattern I spray or wipe on mineral spirits. I loosens the glue and the pattern peels right off, if not I apply a little more. once all the pattern is off I wipe it down again to make sure all the glue residue is gone, let it dry and apply finish as usual
Thanks everyone.  I have used Reverse Tooth blades but I still got fuzzies.  I would NEVER use a torch I don't trust me or it, :lol:  afraid of burning the whole thing.  I hate spirals.
And Dick I DO use a small orbital sander every time I scroll something, I just need to make it courser sand paper obviously.  So I may add a trow away piece at the bottom and see if that helps me.  Thanks for all of your answers, I also think it was a good topic for all of the newbies.
Marg
To answer your question - Yes.  To explain my answer - Sometimes I use a trow away piece.  Sometimes I don't.  (Like the old commercial "Sometimes you feel like a nut, Sometimes you don't.") Depends on what blade I use, what wood I use, and mostly if I remember to add one.  When I am cutting, I use my 4 in 1 tool.  Cut awhile and while giving the saw a break, sand the bottom of the bottom piece with the 4 in 1.  Gives some support when sanding.  Cut some more, sand, etc.  When cutting is finished only a little left to sand on the bottom. Plus I think removing the fuzies as I cut makes the wood move better.  I hand sand or use orbital sander.  Even when I have piece wraped in painters tape, I will sand but by hand then.
Larry
