Ornaments For Charity eBook - Designers Wanted! ​​​​​​​🙏 ×
CHILIES,ROSA,& SAW BLADE
amazingkevin
Great work Kevin! :thumbs:  :thumbs:  :thumbs:  I have been looking at the saw blade pattern for quite a while but haven't taken the time to cut it.
Here is the link for the deer on the saw blade pattern.
http://www.scrollsawvillage.com/gallery/image/4727-saw-blade-buck-in-water/
By the way, paint the pepers. Lol
Kevin with Food Coloring and Denatured Alcohol you will need to test a piece as it can be a little weird to use the first time.  Other than that it is fairly simple to use.  As for taking good quality pictures make a box about 2 feet on a side.the sides, top and back are all open.  Drape a white sheet over the box leaving the front open.  Arrange strong lighting to shine on the box from the sides and top.  The sheet will cause the light to spread out and give you an even light for when you take your pictures.
DW
More great ones.  I may have to do a couple saw blade ones.  I really like them.  Is there a pattern around for the saw blade or I trace one of my blades?
You could take the pattern in the link up above and just use the saw blade part and then put anything you want on it. just lay your pattern right over the saw.
I believe when I made this pattern I just got a generic picture of a saw blade off the net and used it. You could do as Danny said as well. Delete my pattern from it and use the outline of my blade
