I have an EX-21 and a DW788  and top feed with both.  Got used to it and now feel strange doing it any other way.  Tried a couple times to bottom feed with my EX but found it more difficult to clamp the blade in the upper blade clamp.  Old man stuck in his old ways I guess.
Al
Hey Kevin, I don't know you well enough yet to know if your kidding or not, but yes, the DeWalt DW788 is a top feeder. Of course you can bottom feed on it.
Thanks DG,the more i know about scrolling the more i too can pass it on ,thanks!P.s. i did'nt know
My saw is a Dw788 but I bottom feed as I find when ever I top feed my blade always gets stuck behind the holder instead of in front also find it hard to push the blade through that tiny hole with the teeth pointing down.
Have owned three other saws along with what I use at present....HEGNER....  All have been Bottom Feeding.  The Hegner ONLY FEEDS BOTTOM.
Side note....  Seems if TOP FED you have to attach to bottom of the blade IN THE BLIND.  Can't imagine doing it.    Danny  :+}
Hey Danny, yes you do attach the blade "in the blind", but it becomes secund nature after a little practice. I can change from hole to hole without looking at the bottom clamp in about ten seconds and you don't have to lift the work off the table.
I've tried top feeding many times and really struggle with it.  I have an Ex - 21.  I find it very difficult to line the hole I am feeding the blade through with the hole in the table.  On the Ex there are holes around the blade hole and I often get the blade fed into one of those holes.   I think I just not coordinated enough for top feeding.  I'm a carp. :oops:
After reading all the posts, yesterday I thought I'd give top feeding another try. Nope, just not gonna happen. I think my experience with top feeding is like my experience with spiral blades. Great for others, but not for me.
Great thread though.
Jim
