I'm thinking after the holidays are over and my Mother-Law goes back to Georgia, I will do a video on how I top feed. Not to change minds, but to show how easy it is for those who might want to try. Of course it is dependent on Santa bringing me a movie camera!
On my DW788 I top feed.  I do it all by feel.  It took about 15 - 20 minutes to learn.  I did start off bottom feeding but since I do a lot of larger fret pieces I found it impossible to find the drill holes especially when using the numbered bits.  On my Hawk VS-226 I bottom feed but that is not by choice but because of the saw design.  Needless to say I use the DeWalt more then the Hawk.
I have always bottom fed my works. Don't know if my arm raises high enough without bending the blade to insert in hole. When I bottom feed, I just lift the work piece up enough to remove blade from cut & insert it in the next hole without looking at the under side. It seems to work OK for me. Once in a while I will get a stubborn drill hole & the blade doesn't want to come through. No big deal. Just lift it & insert it the regular way.  Good Luck
Ok now i understand the difference.I'm a BOTTOM FEEDER with the dw788 and all the other almost dozen saws i've had.I don't want to deal with fastening the blade where i  can't see what's going on.Especially with wood keeping the blade from being straight  up and down.
I would  be a top feeder if I could solve a problem. Attaching the blade to bottom clamp blind is easy!
Putting the blade thru the drill hole a little harder, I can do that ( teeth point down )
But
Three times I tried top feed and failed!  How do I align hole in wood with hole in table?
How do I align hole in wood with hole in table 500 times?  A 1000, 10,000 and never miss it?
Edited by LarryEA
