Merry Day After Christmas folks!!
The other day I ran into a strange what the heck issue with my EX21.
Put in a new blade, flipped the tension lever, and started to cut.
Particulars: Pegas #7SPR blade cutting 3/4 pine. After a few seconds of cutting the tension lever flipped forward!! :cry:
Tried several times, same result. Tweaked the cam stop a teensy bit, reset the blade, still happening. :grr:  Changed to a #5R blade, no issues, several other type/size blades, no issue. :lol:
Tried the #7 SPR again and within a few seconds the tension lever released. :o
Anyone out there ever experience something like this? :huh:
i'll just bet you got finger oil on the end of the blade .Clean the blade and blade holders and try again!I clean with mineral spirits  and put some folded over #240 sand paper in where thje blade goes ,tighten the thumb screw ,back off a little and slide the sandpaper up and down a few times to roughen it up and remove and lodged oil & dirt.Happy scrolling now!
Happened to me too, I replaced the tension lever and had no more problems, the original had a tiny bit of wear but it makes a difference. Tillmy new one arrived I held it in place with a rubber band.
Edited by Docupton
Yep been cutting 3D chess sets using 7 polar same thing happened. I checked the lever seemed OK slowed down did little better then cleaned with mineral spirits worked well for a while then did again noted dust blew it out is working well again. I just blame it on the gremlins.
  • 2 weeks later...
Larry, it's a round about way of swearing, without actually saying the words. What The Duck, change the D to a F and you got it. |Some people will change the last word, but, in the real world it means what I've typed.
Len
