courtym74 Posted December 27, 2014 Report Posted December 27, 2014 Hello all. Has anyone had any experience with the delta 40-694 scrollsaw? I've had mine for about six months now and it's been great. Today I was cutting a thicker piece than usual, the blade broke and now the motor is loose. Can turn it maybe 1/8 of an inch. When its let go it makes a thunk or rattle noise. If I hold it turned then its fine. Any tips on tightening it? From the looks of it I need to disassemble the whole thing to get at the motor mounts. Please someone tell me this isn't the case. OCtoolguy 1 Quote
LarryEA Posted December 27, 2014 Report Posted December 27, 2014 (edited) That is the case! If the motor is loose, it has to be tightened. Period. I have a 40-690 and if the motor was loose. I would take it apart and tighten it. It is easy, just takes an 1/2 hour to disassemble. I'm asssuming the 40-694 is similar Take the table off by unscrewing the screw on the front. (Heavy, don't bend screw) Remove the nut in the back that secures the saw to the bench. Now all you need is a star bit, 1/4" and 1/2" box wrench. Remove attached light Power Switch Cover -- remove 4 screws (remove cover later). Remove the 'U' clip screw that the table mounted to, Slip off the U clip. Remove the two screws require 1/4" wrench ( External nuts visable on outside) Remove the two screws on the front bottom that secures the saw to the bench. Lift the saw off the bench and lay it on its side with the motor off the table. (No weight on the motor). Remove the rest of the screws. (one screw is longer than the rest, some have washers (make note). Remove Arm Plate and switch cover. The back cover (opposite motor) has tight fit, work loose slowly. check and tighten motor screws. Re-apply or add grease where there was grease. There is metal plate 1 1/2" x 1 1/4" (approx) you need to align to put back cover on. Also insure you do not crimp wires when you put cover on The last screws are the ones that attach saw to bench, then the nut on the back. Edited December 27, 2014 by LarryEA OCtoolguy 1 Quote
LarryEA Posted December 27, 2014 Report Posted December 27, 2014 (edited) Use lock washer if needed on motor No Locktite on any screws/nuts (any that hold covers on) Edited December 27, 2014 by LarryEA OCtoolguy 1 Quote
courtym74 Posted December 27, 2014 Author Report Posted December 27, 2014 Thank you Larry. I assumed this was the case but since I've never opened one up before I was a little leary of screwing something up in the arms and such. I'll give it a go and let you know what happens. Thank you again! OCtoolguy 1 Quote
LarryEA Posted December 27, 2014 Report Posted December 27, 2014 (edited) Matt, Updated Directions, please note changes/additions Don't think I missed anything. Wish you the best. I had mine apart 3 or 4 times looking for a self-induced problem. It became easy on the last one. (Self- induced problem is where you look in the wrong place for a problem you don't have and cause a real one) I pinched a bunch of wires putting it back together. Edited December 27, 2014 by LarryEA OCtoolguy 1 Quote
Scrolling Steve Posted December 27, 2014 Report Posted December 27, 2014 Good luck Matt!..........Sounds like you are in good hands with Larry's instructions. OCtoolguy 1 Quote
dgman Posted December 27, 2014 Report Posted December 27, 2014 Wow Larry, that was great directions! I don't have that problem but I'm sure this will help others! OCtoolguy 1 Quote
amazingkevin Posted December 27, 2014 Report Posted December 27, 2014 You can count on great help from dedicated members every time!Thank you LarryEA OCtoolguy and WayneMahler 2 Quote
JustLarry Posted December 27, 2014 Report Posted December 27, 2014 Just a reminder - the new 40-694 comes with a 5 year warranty. However, if the repair center is not close by - mine is 150 miles away - may make the warranty not very good. A day getting it there. Another day to pick it up. If mine needs it, it is take apart and get er done time. Study the parts diagram and take pictures as you take apart. http://www.ereplacementparts.com/delta-40694-variable-speed-scroll-saw-parts-c-3275_3505_418339.html?q=40-694 http://www.ereplacementparts.com/delta-40690-type-scroll-saw-parts-c-3275_3505_157559.html?q=40-690 (page B) Larry OCtoolguy 1 Quote
courtym74 Posted December 27, 2014 Author Report Posted December 27, 2014 Got it going!! Can't believe how loose some of the screws in the motor were! Several turns to tighten them! You'd think in a machine that is made for making vibrations they'd but some lock washers on them! The 694 was a bit different from yours Larry but it was still pretty straight forward. Thank you again for your tips and tech!!! OCtoolguy and WayneMahler 2 Quote
LarryEA Posted December 28, 2014 Report Posted December 28, 2014 Got it going!! Can't believe how loose some of the screws in the motor were! Several turns to tighten them! You'd think in a machine that is made for making vibrations they'd but some lock washers on them! The 694 was a bit different from yours Larry but it was still pretty straight forward. Thank you again for your tips and tech!!! Hey Matt, You are welcome. Good to hear. Wasn't too bad,HUH. I'm telling everyone, I have the 40-694 arriving Tuesday Dec 30th. I love my 40-690, it is running great, I'll give it a rest and see how the 694 compares. OCtoolguy 1 Quote
profrpowell Posted October 11, 2018 Report Posted October 11, 2018 I have the same saw. I have put lock washers on motor but it still continues to come loose. Suggestions? Very frustrated!! OCtoolguy 1 Quote
kmmcrafts Posted October 12, 2018 Report Posted October 12, 2018 (edited) 5 hours ago, profrpowell said: I have the same saw. I have put lock washers on motor but it still continues to come loose. Suggestions? Very frustrated!! I'd use the blue loc-tite.. Blue is for medium duty.. Never ever use Red loc-tite unless you never plan to take it apart again, LOL.. actually the bottle instructions on the red says it'll come apart but only with heat from a torch.. Not sure if they mean heat from a cutting torch or just heating it up a little to loosen the loc-tite Edited October 12, 2018 by kmmcrafts OCtoolguy 1 Quote
amazingkevin Posted October 12, 2018 Report Posted October 12, 2018 I think acetone will unlock the lok-tight. kmmcrafts and OCtoolguy 2 Quote
MrsN Posted October 12, 2018 Report Posted October 12, 2018 @profrpowell How often do you have to tighten the bolts that hold the motor? OCtoolguy 1 Quote
OCtoolguy Posted October 12, 2018 Report Posted October 12, 2018 3 hours ago, MrsN said: @profrpowell How often do you have to tighten the bolts that hold the motor? I would think that if you were to use the blue LokTite you would only have to do it once. kmmcrafts and John B 2 Quote
Woodmaster1 Posted October 13, 2018 Report Posted October 13, 2018 I had a similar problem with my Delta 40-694. You have to take it apart to get to the bolts in the back. I tightened my motor and have had no problems since. Apparently the guy tightening the bolts got tired and let a few through. Watch Gwinnett woodworks video on the Dewalt repair and your good to go. John B and OCtoolguy 1 1 Quote
