Not really related to scroll sawing but would anyone know where I could find a set of brass gauge setup blocks that start at 1/16" & up, all the ones I find start at 1/8" and up.  If I could find a 1/16" I could add it to the sets I found.  Anyone know where I can find such a animal?
I found a small set @ MLCS 2 3/8" long that will do for now, I really wanted a set 4" long but these will do.  I went & looked at the Veritas set but I already ordered the small set from MLCS.  Thanks for the info anyway.
Kevin, all they are is a set of brass set-up blocks, the set I own measures from 1/8" to 1/2". What they are, is small strips or pieces of brass that are used to set the height of a cut. You lay them flat on the table of your saw, and then you raise your blade to the height of the block. That gives you your measurement, you can use two or three of the set-up blocks combined to get the measurement you want, which is usually depth of cut. I no longer use the set I own, I bought an electronic depth gauge, and I use it to get a more exact measurement easier. Hope this explains it good enough for you to understand what they are. You must of seen a set of these over the years, but just didn't know what they were used for, hey, we're all like that sometime.
Len
My luck, MLCS called this morning and said the set I ordered has been discontinued.  So I ordered the Veritas set of 2" long starting at 1/16", guess they will have to do.
Edited by tvman44
