Multifasited Posted January 11, 2015 Report Share Posted January 11, 2015 For those of you using a big shop vac interested in saving your vac unneeded wear and eliminate a lot of extra fine dust in your shop ,from the vac allowing ultra fine dust to recirculate in and out of your vac. put a sheet rock bag in your shop vac .stops ultrafine dust from getting to your motors ,bearings & brushes and exiting your vac, thru the exhaust port ! Available Lowes or HD in 3 pack ! cheaper than hwd,store ! Not real cheap but very effective and cheaper than a hepa by a dam site .with a separator ,Fein or dust dep.last very very long time ! Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted January 11, 2015 Report Share Posted January 11, 2015 For those of you using a big shop vac interested in saving your vac unneeded wear and eliminate a lot of extra fine dust in your shop ,from the vac allowing ultra fine dust to recirculate in and out of your vac. put a sheet rock bag in your shop vac .stops ultrafine dust from getting to your motors ,bearings & brushes and exiting your vac, thru the exhaust port ! Available Lowes or HD in 3 pack ! cheaper than hwd,store ! Not real cheap but very effective and cheaper than a hepa by a dam site .with a separator ,Fein or dust dep.last very very long time ! What's that, have you got a picture never heard of a sheet rock bag before.???? Roly Quote Link to comment Share on other sites More sharing options...
Multifasited Posted January 11, 2015 Author Report Share Posted January 11, 2015 Not much to look at,vac .bag made special for sucking up sheet rock sanding dust after sheetrocker use big orbiting sanders finishing houses ,started out as speciality item ,but is now available for renters of those machines , DIY,Stops ultra fine dust ,if you ever dealt with sanding sheet rock ,that stuff is like talcum powder and will go straight thru a standard vac (like a dose of salts) It's a special type Paper ,vac bag designed to fit larger shop vacs . I think it would catch flea dust ! (If you know what I mean! They make DIY manual smaller rock sanders for sheet rock ,but smaller bags are hard to find ,maybe on the net ,for those using smaller units ,4-5 gal size,I'm guessing ! Rental places should have as well but usually higher priced ! Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted January 11, 2015 Report Share Posted January 11, 2015 Not much to look at,vac .bag made special for sucking up sheet rock sanding dust after sheetrocker use big orbiting sanders finishing houses ,started out as speciality item ,but is now available for renters of those machines , DIY,Stops ultra fine dust ,if you ever dealt with sanding sheet rock ,that stuff is like talcum powder and will go straight thru a standard vac (like a dose of salts) It's a special type Paper ,vac bag designed to fit larger shop vacs . I think it would catch flea dust ! (If you know what I mean! They make DIY manual smaller rock sanders for sheet rock ,but smaller bags are hard to find ,maybe on the net ,for those using smaller units ,4-5 gal size,I'm guessing ! Rental places should have as well but usually higher priced ! Got it Carl it's a brand name for what we call drywall over here that explains why I didn't know it. Ain't Google great! Roly Quote Link to comment Share on other sites More sharing options...
Multifasited Posted January 11, 2015 Author Report Share Posted January 11, 2015 Showing my age again ,the youngsters over here call it dry wall too ,I went in and ask for linoleum ,everybody looks blank (say What)so I explained it's use (Oh! you want, vinyl sheet goods!) I forgot, I came over on the May Flower again ! Silly me I still refer to Gay as Happy ! You can guess the rest !! I AIN'T Cool NO MORE!!! Jim Finn and Fab4 2 Quote Link to comment Share on other sites More sharing options...
Fab4 Posted January 11, 2015 Report Share Posted January 11, 2015 (edited) Showing my age again ,the youngsters over here call it dry wall too ,I went in and ask for linoleum ,everybody looks blank (say What)so I explained it's use (Oh! you want, vinyl sheet goods!) I forgot, I came over on the May Flower again ! Silly me I still refer to Gay as Happy ! You can guess the rest !! I AIN'T Cool NO MORE!!! Hi Carl: Your still "Cool" to us here at the village Keep it that way Fab4 I would have asked for linoleum also......lol Thanks for the tip on the "whatchamacallit bag" Edited January 11, 2015 by Fab4 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted January 11, 2015 Report Share Posted January 11, 2015 For those of you using a big shop vac interested in saving your vac unneeded wear and eliminate a lot of extra fine dust in your shop ,from the vac allowing ultra fine dust to recirculate in and out of your vac. put a sheet rock bag in your shop vac .stops ultrafine dust from getting to your motors ,bearings & brushes and exiting your vac, thru the exhaust port ! Available Lowes or HD in 3 pack ! cheaper than hwd,store ! Not real cheap but very effective and cheaper than a hepa by a dam site .with a separator ,Fein or dust dep.last very very long time ! Thank you Carl,here's the link to said product LANDA Vacuum Bag for Drywall Sanders Quote Link to comment Share on other sites More sharing options...
herrwood Posted January 12, 2015 Report Share Posted January 12, 2015 Showing my age again ,the youngsters over here call it dry wall too ,I went in and ask for linoleum ,everybody looks blank (say What)so I explained it's use (Oh! you want, vinyl sheet goods!) I forgot, I came over on the May Flower again ! Silly me I still refer to Gay as Happy ! You can guess the rest !! I AIN'T Cool NO MORE!!! I know what you mean I asked a transistor battery (needed a 9 volt) and got a strange look from the college age clerk . Quote Link to comment Share on other sites More sharing options...
Multifasited Posted January 12, 2015 Author Report Share Posted January 12, 2015 As far as the young folks think ,Your , Brother had a proceedure , !And your looking for her & her new friends hang out ~The transister battery ! TIMES SURE HAVE CHANGED ! Quote Link to comment Share on other sites More sharing options...
