It's built for kids to actually play on. The wheels turn and the handle bar and front fork assembly move. I think I did a work in progress on one here on this site a while back if you're interested in checking out how one is put together. They are actually not nearly as hard as they look. They are quite time consuming though. I have around forty hours work in each of them. Everything except the rockers are cut on a scroll saw. The rockers are done on the band saw. Everything is put together. Then you sand all the parts to fit properly. Then you take it back apart for staining, or painting if you wish. Then you put it all back together again. In final assembly, all my parts are put together with glue and screws. Then I countersink all the screws and plug the holes with 3/8 dowel that I cut into small pieces. Then I touch up the wood where the dowels are.
If you check my photo album, I also make a rocking train, tractor, and pig. Also, I recently done a carousel horse with rockers, but it is an art piece, not for playing on.
