amazingkevin Posted January 25, 2015 Report Posted January 25, 2015 Won't you be a happy camper to complete this one!It looks like way to much for me to tackle!HAVE AT IT! Quote
Savannah Scroller Posted January 25, 2015 Author Report Posted January 25, 2015 GRRRRRRRRRR-I HAVE SCRAPPED AND STARTED OVER THREE TIMES THE LARGE SIDES. I HATE WORKING WITH PLYWOOD . i AM TRYING TO USE OAK PLYWOOD . MABEE I SHOULD HAVE TRIED USING BIRCH INSTEAD? GATOR WHAT DO YOU THINK ABOUT IT?THE PROBLEM THAT I AM HAVING IS THE WOOD SPLINTERS WHEN I DRILL THE 5/16 HOLES FOR THE PEGS ON THE BACKSIDE OF THE WOOD ,WHICH IN THIS CASE IS GOING TO BE VISIBLE NO MATTER WHAT YOU DO Quote
Scrappile Posted January 25, 2015 Report Posted January 25, 2015 (edited) What kind of a bit are you using to drill the hole? A brad point or forstner bit would is what I would use for that. Edited January 25, 2015 by Scrappile Quote
Kevx Posted January 25, 2015 Report Posted January 25, 2015 I was thinking about this and had a few ideas that might help. First, if you stack cut with one of those scrapped pieces placed on the bottom, I think the good pieces would stay mostly splinter free, while the scrap piece would take most of the splintering. I also see people taping the entire underside of the wood to hold it together. I think these sound like good ideas, and possibly using less aggressive drill bits. Quote
amazingkevin Posted January 25, 2015 Report Posted January 25, 2015 I was thinking about this and had a few ideas that might help. First, if you stack cut with one of those scrapped pieces placed on the bottom, I think the good pieces would stay mostly splinter free, while the scrap piece would take most of the splintering. I also see people taping the entire underside of the wood to hold it together. I think these sound like good ideas, and possibly using less aggressive drill bits. Kevx is right ,but it's something i rarely do ,i hate to waste precious wood just for some splinters. Quote
LarryEA Posted January 25, 2015 Report Posted January 25, 2015 GRRRRRRRRRR-I HAVE SCRAPPED AND STARTED OVER THREE TIMES THE LARGE SIDES. I HATE WORKING WITH PLYWOOD . i AM TRYING TO USE OAK PLYWOOD . MABEE I SHOULD HAVE TRIED USING BIRCH INSTEAD? GATOR WHAT DO YOU THINK ABOUT IT?THE PROBLEM THAT I AM HAVING IS THE WOOD SPLINTERS WHEN I DRILL THE 5/16 HOLES FOR THE PEGS ON THE BACKSIDE OF THE WOOD ,WHICH IN THIS CASE IS GOING TO BE VISIBLE NO MATTER WHAT YOU DO It will cost time but you can drill twice. Smallest bit you have first then use larger bit on one side just countersink, turn over and drill through... Quote
Kevx Posted January 25, 2015 Report Posted January 25, 2015 It will cost time but you can drill twice. Smallest bit you have first then use larger bit on one side just countersink, turn over and drill through... I thought about this too, and then I thought about how many inside cuts he has to do on this pattern! But if that's what has to be done to do it right, I would do it. Then on to a bigger problem; You have to keep that plywood from splintering when you do the cuts too. I think I would try out different blades on scrap pieces before I'd risk any cuts on that piece you've already invested so much time on. Quote
heppnerguy Posted January 26, 2015 Report Posted January 26, 2015 Another idea that i do sometimes is use a 1/16 inch drill bit and then I cut the circle with my saw. It always comes out well for me when I do that. always be sure that you are using a sharp drill bit and your work piece is also sitting another board that is placed on your drill press. Hope this might help Dick heppnerguy Quote
tomsteve Posted January 28, 2015 Report Posted January 28, 2015 Sharp drill bits, higher rpms, and a solid piece of wood underneath to let the drill bit to keep drilling into helps me stay splinter free when drilling. And letting the drill bit do the work. Quote
Wilson's Woodworking Posted January 28, 2015 Report Posted January 28, 2015 I am looking forward to seeing in proses pictures. Quote
