loghome Posted September 11, 2009 Report Posted September 11, 2009 Hi, If any one can help me that would be great! I am using a #2 R on birch plywood.And on pretty much all of my cuts their is fras on the top of the cut not the bottom :?h plywood Thank you! Quote
grampa Posted September 11, 2009 Report Posted September 11, 2009 Hi , do you have the blade in with the teeth cutting in the right direction. Its easely done with fine blades Paul Hi, If any one can help me that would be great!I am using a #2 R on birch plywood.And on pretty much all of my cuts their is fras on the top of the cut not the bottom :?h plywood Thank you! Quote
ron w b Posted September 12, 2009 Report Posted September 12, 2009 i agree with grandpa check the teeth they should be pointing down Quote
britetomro Posted September 12, 2009 Report Posted September 12, 2009 I have found on the smaller blades and also the spirals, you can pull the blade through your thumb and first finger and you should be able to feel the direction of the teeth. You can also use your finger nail to get the same results. Quote
wood-n-things Posted September 12, 2009 Report Posted September 12, 2009 Yep the blade is probably in upside down..You can sometimes tell by releasing pressure on your work piece ..the saw blade will lift the wood off the work surface causing it to chatter... Quote
greasemonkeyredneck Posted September 12, 2009 Report Posted September 12, 2009 I am positive the blade is upside down. There have been times that I was sure my blade was in right. I use almost nothing but spirals. According to "feel" the blade will be right. I'll start cutting though and the "fuzzies" will be on top instead of bottom. I'll turn the blade around and everything will be back to normal. Quote
loghome Posted September 12, 2009 Author Report Posted September 12, 2009 Thanks A lot everybody for the good advise. Glad I got help so fast ! Will change the blade around pronto Quote
