gator Posted February 2, 2015 Report Posted February 2, 2015 got a question air hose is real loose on first knuckle at machine. so wont stay put. any tips and a few extra knuckles to make it longer . where can we buy more of them? Quote
Scrolling Steve Posted February 2, 2015 Report Posted February 2, 2015 Gator, Seyco sells an blower kit but that may be more than you need......Try Harbor Freight if you have one in your area! Quote
jrpeteo Posted February 2, 2015 Report Posted February 2, 2015 You may find something useful here: http://www.modularhose.com/ I doubled the length of hose on my old Craftsman. You can add/subtract as much hose as you like, heat it up a bit to work with it. Pete Scrolling Steve 1 Quote
amazingkevin Posted February 2, 2015 Report Posted February 2, 2015 I'd like a surgical rubber one that goes up and down with the blade and stays out of my way and stays put. Quote
Multifasited Posted February 2, 2015 Report Posted February 2, 2015 Kevin ,has been operating again ,that multi -talented rascal ! Quote
tomsteve Posted February 2, 2015 Report Posted February 2, 2015 The blower hose on the ex is called loc line. If you have a machine/ indrustrial supply store nearby! Something like production tool, you could take what ya got ther and they should be able to hook ya up with more. To tighten up a knuckle you can try moving their position. Or http://www.mrmsworkshop.com/uploads/1/8/1/8/18181809/air_hose_repair_information.pdf Quote
Doug Posted February 2, 2015 Report Posted February 2, 2015 (edited) You may find something useful here: http://www.modularhose.com/ I doubled the length of hose on my old Craftsman. You can add/subtract as much hose as you like, heat it up a bit to work with it. Pete I agree with Jerry - I had to replace mine and purchased from the web site he shows. Unless you are really on a strict budget for the cost of a couple of six packs or a small pizza I would also recommend the tool for assembly of the lines - heat and hot water can work but even then their is a large amount of frustration and you should not do it when young children or your pastor are around. http://www.modularhose.com/Loc-Line-14-System/14-hose/78001 Edited February 2, 2015 by Doug Scrolling Steve 1 Quote
dgman Posted February 3, 2015 Report Posted February 3, 2015 The reason your hose is loose at the first segment is it is cracked. Make sure you remove that segment or it will continue to be loose. Quote
gator Posted February 3, 2015 Author Report Posted February 3, 2015 thanks guys when i getback home i will take it off and go to a machine supply house got a bunch down here in houston Quote
