Paul,
  If you started a box, I would not expect it to be anything but a lot  of fret work involved.. I am going to sit down before I open the post on that box.  good luck, pal. I bet t will be a thing to behold
Dick
I started a box this evening that has a lot of fret work involved.  It is to made out of 1/4" material.  That is what the plans call for.
3/8 makes for a little more hefter box.
Especially if you want to put a sliding top on the box.  (allows more recess in the side panels.)
Thats just my two cents worth.
I am sure what ever you tackle it will be outstanding.
Later
Jamminjack
I looked at the pattern and it said 1/4". The top and sides are scrolled out. the top and bottom are 13" X 6" and overlap the sides a little. The sides are around 4" tall. I tried to take a picture of the pattern with my phone and it wouldn't upload very good. I will try to take a picture later, I am getting ready to go to work.
Personal preference   I would go with cherry.
Very classy, cuts well, always a top seller.
Thats my 2 cents worth.  But what do I know, look at my avatar, does that tell you anything?  .
Later
Jamminjack
 Har, I woulda thought your personal preference was 'corn'.  Corn use to sell good down in the valley. ;)
Never 'cut' corn, it was always 'straight up'. hehehehe :razz:
I now see, after seeing the pattern, that the box has a fretwork top.  I do not do fretwork, I do inlay, so my advice does not apply here.  I should know better, most people with scroll saws do a lot of fretwork and they assume everyone does and do not mention it in their posts.  My mistake.  I have no idea what thickness is best for fretwork.
