Jonathan Shockley Posted February 17, 2015 Report Share Posted February 17, 2015 (edited) So I'm new to scroll sawing and I just bought a Hegner, mainly to cut out simple patterns for slingshots that I want to sell (just a few over and over again). The other day, when I was trying out the saw, I cut out a few patterns using a photocopied blueprint (see pic) Unfortunately, the glue was kinda hard to remove. Is this the best way to cut out patterns, or is there any other way? Edited February 17, 2015 by JonathanShockley AlfrediaMum 1 Quote Link to comment Share on other sites More sharing options...
ducky Posted February 17, 2015 Report Share Posted February 17, 2015 try using a hair dryer on the paper m8 my help soften the glue... Jonathan Shockley 1 Quote Link to comment Share on other sites More sharing options...
Scrolling Steve Posted February 17, 2015 Report Share Posted February 17, 2015 A lot of us use painters tape on the wood, then glue the pattern onto the tape. remove the tape and the pattern comes with it. Jonathan Shockley 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Shockley Posted February 17, 2015 Author Report Share Posted February 17, 2015 Very smart Steve, Thanks! Quote Link to comment Share on other sites More sharing options...
Kepy Posted February 17, 2015 Report Share Posted February 17, 2015 For a simple design that you will be cutting numerous times, it is easier to cut a template from something like 1/8" masonite that you can draw around and then cut. Jonathan Shockley and Scrolling Steve 2 Quote Link to comment Share on other sites More sharing options...
ike Posted February 17, 2015 Report Share Posted February 17, 2015 on simple jobs like you want just draw on the wood off of a template. for more completed jobs use the painters tape . Jonathan Shockley 1 Quote Link to comment Share on other sites More sharing options...
Clayton717 Posted February 17, 2015 Report Share Posted February 17, 2015 As othere have said, if your making several of a simple pattern make a pattern out of thin stock. I use poster board alot for this. when I glue patterns to wood I use mineral spirits on a rag a just wipe over it, it softens the glue and the pattern peels off Jonathan Shockley 1 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted February 17, 2015 Report Share Posted February 17, 2015 As othere have said, if your making several of a simple pattern make a pattern out of thin stock. I use poster board alot for this. when I glue patterns to wood I use mineral spirits on a rag a just wipe over it, it softens the glue and the pattern pee I've been doing it CLAYTONS way all my scrolling years and have no complaints.But its best to use none permanent spray glue or temporary tack spray glue Jonathan Shockley 1 Quote Link to comment Share on other sites More sharing options...
Scrappile Posted February 17, 2015 Report Share Posted February 17, 2015 I agree with most, for repetitive cuts of larger item, as you are doing, a template is the way to go. If you get into small thing or fret work, here is a nice little video of different ways to attach/remove patterns. Jonathan Shockley and Scrolling Steve 2 Quote Link to comment Share on other sites More sharing options...
LarryEA Posted February 18, 2015 Report Share Posted February 18, 2015 You cut that enough times, you won't need a pattern Jonathan Shockley 1 Quote Link to comment Share on other sites More sharing options...
tvman44 Posted February 18, 2015 Report Share Posted February 18, 2015 I know this is a Scrollsaw forum, but if I was cutting out something like slingshots over & over I would use a router and a pattern bit. Just MHO. Quote Link to comment Share on other sites More sharing options...
