I finished my latest motorcycle. I made a few changes. The biggest change was that where I usually never use paint on kid's toys, I added silver paint to this one. I changed the rim design to four holes instead of eight for a little bit different look. I also used some different color stains on other parts too.
I played around with the brightness of these photos in Windows. Let me know if that's any better than my other photos.
Terrific work!
The pics could do with a little lift though :) -- (you did ask)
I have tried to find the simplest and quickest way. Download Picasso from here:-
http://picasa.google.com/thanks.html
It will download and install in seconds. If you do not want Google as your Home Page then deselect the option on the last screen.
Open the prog: All pics on your PC will appear on the right hand side. (You may also "drag" an image into the program)
Double click the one you need to edit. This will open in a new frame. Have a look at "basic fixes" and try Auto Contrast - that may be all you require. You can also fine tune from one of the tabs but that may not be needed. Save it when finished.
The pics below were dealt with by Auto Tune only and took seconds with nothing to learn.
I will delete these from my folder when you have seen it.
HTH
Cheers
Keith
EDIT Images deleted from folder as per above :)
Thanks for the photo advice. That's an ongoing process of improving my photos. I minly want to improve the photos of my finished projects. My in progress photos will just have to do. I'm not taking the time to worry with them. The village is the only ones who see them anyway. I am working on it though, I promise. I do think the photos I posted here are better than my previous ones though.
  • 1 month later...
