Here is what I believe. There are several patterns out there that is supposed to help you put more hold down pressure on your blade , if you uses it. Steve Good has made one of the patterns for free, on his web sight. They really do the job well but a word of caution. They also put much added strains on the saws thumb screw. I made one for my saw because the blades seem to work loose as I was cutting a pattern and this added wooden piece that was put over thumb screw accomplished what I was after. I was really happy that I had discovered this helpful pattern. However, in a rather short time, I discovered that my had stripped and I was now waiting a replacement for my stripped part. Shortly after replacing my set screw, I read an article that was warning against using such a device on my saw because it would eventually cause the thumb screw to stip. What now ? Then I read about the thin layer of protective oil on the new blades and that they needed to oil free. I found out I needed to clean off that oil layer. I use a small piece of sandpaper that I always have by my saw. Never does another blade get put into me saw until it is sanded on both sides of each end of the blade. I only need to hand tighten the thumbscrew, with no kind of additional tool. That was several years ago and I have not had another thumbscrew stip on me since.
Dick
heppnerguy
Dick, Thanks for posting why you had to replace your clamp assembly. I made the add-on you referred to. It didn't strip the threads, but After about 6 months of use, it spread the clamp apart so the knob screw and set screw didn't line up.
Woring in a machine shop  for 52 years i learnt that anti siege works best on set screws it allows you to tighten set screws with less force and it makes it easier to remove the set screw. A $5 tube will last a stroller a life time
Dick, you have reminded me of an important step that i have been forgetting.  I am purely self taught and recall hearing about sanding the sides of the blades.
Does this help straight cutting?  Would this help my band saw too?
I have a pinned Frejoth.  I have never cut on another saw. I wonder whether it vibrates more than others.
Graeme
