qlty Posted September 26, 2009 Report Posted September 26, 2009 The one problem I have with pine is even though I sand the cutting surface and cover the pattern with clear packing tape if the wood has much pitch in it the saw dust piles up in damp curls on the cutting line and the blower does not remove it very well .I have to stop and brush it off.Wondering if any one has a solution to this problem?? Quote
merlin Posted September 26, 2009 Report Posted September 26, 2009 Yeah have the same problem here (NZ), now don't know if your pine is the same as your pine or not but it sounds like it. I try not to use tape for the reason you gave about the dust curling and building up. (that wood be the resin, pith and the tape glue all combining, a mess and pain.) Have a go without the tape and sea if that helps at all. Merlin Quote
wood-n-things Posted September 26, 2009 Report Posted September 26, 2009 I have to be a little more careful when cutting pine so that I get good adhesion and no curls or bumps. Then it seems to be okay. Quote
FD Mike Posted September 26, 2009 Report Posted September 26, 2009 Why not using blue painters tape on top of the wood and glue pattern on top of that. Mike Quote
ugsduck Posted September 27, 2009 Report Posted September 27, 2009 I got around this by disconnecting the inbuilt air and installing a cheap aquarium pump that delivers more powerfull and constant air whatever the speed of the arm. Quote
macfil20 Posted September 30, 2009 Report Posted September 30, 2009 I'm using blue tape on the pine then glue the pattern on the tape. I don't have anymore problem. JP Quote
BuLLdoGG Posted October 15, 2009 Report Posted October 15, 2009 I to disconnected the onboard air system and put a aquarium pump on works fine Quote
