olddust1 Posted April 5, 2015 Report Posted April 5, 2015 (edited) Sorry for the out of focus but you get the idea. Jhn Old Dust OOPS "Warrior" WW compound 1.pdf WW compound 2.pdf Edited April 6, 2015 by olddust1 Smudger 1 Quote
DWSUDEKUM Posted April 6, 2015 Report Posted April 6, 2015 John is that pattern available? Thanks for sharing this with us. DW Quote
LarryEA Posted April 6, 2015 Report Posted April 6, 2015 I had a problem opening. I do thank you for showing your work tho I could not view it. Quote
amazingkevin Posted April 6, 2015 Report Posted April 6, 2015 Yes very out of focus ,worth redoing please! Quote
Lucky2 Posted April 6, 2015 Report Posted April 6, 2015 Very interesting cutting John, I've done some of this type of work years ago. I have a book of patterns that has a lot of these types of patterns in it, but, this is a new one. Would you mind sharing where you got it, or who the designer is? They're a tricky bit of cutting aren't they, what type of blade did you use? |If memory serves me right, I think that I used two-way blades. Len Quote
lawson56 Posted April 6, 2015 Report Posted April 6, 2015 From what I could see,looks like some very fine cutting.Thank you for showing us.I would like to see it again. Quote
frankorona Posted April 6, 2015 Report Posted April 6, 2015 Hi, I have a problem when I open the file, the images are blurred. Quote
olddust1 Posted April 6, 2015 Author Report Posted April 6, 2015 (edited) Sorry about the out of focus but I am a scroller not a photographer. I used the eagle from "128 Compound scrollsaw patterns" by Sam Keener and the Wounded Warrior logo off the web. The trick is to have both patterns the exact same height. I put them both in my Publishing program and resized so each pattern is 1 1/2" wide to use on 2X2 wood which is actually 1 1/2". You could use any eagle silhouette that is taller than wide. John Old Dust Edited April 6, 2015 by olddust1 Quote
Lucky2 Posted April 8, 2015 Report Posted April 8, 2015 John, these are very interesting cuttings, is there no way possible that you might be able to post better pictures? I do believe that there would be more interest, if people could clearly see the subject. I'm not talking about studio quality or anything like that, but, clear so that there's no blurriness. If it's not possible, that's fine what you've posted will have to do. Len Quote
