This is a plaque I made from one of the patterns I bought from Sheila Landry Designs. So far I’ve been commissioned to make 3. It was a big job for a beginner but I’m getting the hang of it. Now I just have to mount it on a base (customer wanted it free standing) and put a finish on it. It’s made of cherry and measures 4†wide x 16†long 3/4†thick. I think in the future I might try putting in a polymer clay inlay that I saw on Steve Good’s website.
Very nicely done.   Polymer clay inlay, I have done a bit of that  you need 15 min per 1/4 inch thickness of the clay for it to harden so a 3/4 in thick sign would need to be in the oven 90 45 min or there about.  The directions are on the packages of the clay normally.
DW
Thank you for the compliments. DW, I will definitely look into the baking times for the polymer. When I do that I might use 1/2 inch or 3/8 stock. The only reason I used 3/4 this time is from pure laziness and not wanting to plane it down. I rarely have thin stock on hand mostly all 3/4 4/4 stock. My bandsaw isn’t terribly accurate and only has a 6†depth of cut so resawing  is limited to say the least. Amazingkevin, I’ve seen some of your work. You are just being modest. You do excellent work.
Edited by Lvmedic3214
