I am a bottom feeder.  Started a project today with lots of tiny cutouts.  For no particular reason, when cutting a pattern, I start on 1 side and work my way across.  Because the drill holes were very small  & close together, it was inconvenient to find &  thread the blade to the next hole.
It FINALLY dawned on me to not work straight across, but to drill a few holes at a time, on random places on the pattern. This way, the next hole is off by itself.
I normally only drill 8 - 10 holes at a time anyway.  This forces me to keep getting off of my lazy b_____ and walking over to the drill press.
jerry
That's pretty much how I do it.  I'll able to sit at the scrollsaw a max of 30 minutes at a time.  Usually I get up about every 20 minutes and drill some more, go see what is happening on the forum or maybe just walk outside for a while.  If I go more than 30 minutes someone is going to have to help me get up.  My back will not take it.  I'm taking a little break right now.
I never thought about 'random' drilling, I usually drill a series of 20 or so.
I plan where I drill. It must be the 'small ' cuts or the ' hard ' cuts first.
Could never continually cut for hours, ... I can do  5 or 10 cuts and then
do something with a different project...
I just started doing the drill a few holes and then cut them out, and do it all over again. I can sit at my saw for hours and not tire from doing so, so, I like to drill a lot of holes and sand the back of the piece of wood to get it ready to cut. I always start with the most difficult and delicate cuts, then move on from there cutting from the middle to the outer edges.
Len
That works however there is the consideration that there will be parts of a complicated cut that will need special attention and may have to be cut sooner so that structurally the cut is safer ( less chance of snapping anything off )  My self on the big complicated pieces I top feed, on most everything else bottom feed.  :)
DW
I drill all my entry holes before i start..mark all hole with the tip of a #2 pencil after sanding....Then cut inside out, with the smallest cuts first....Like DW said, I try to figure where the flimsy parts that will need support are and work those first.........Everyone has their on methods ....Thats just my 2 cents :)  ;)
I only drill 10/15 holes at a time and where it's feasible I also run the drill thru the hole from the opposite side.I also use a awl on the down side where it is feasible
with my try focals it helps..
I drill all the holes before I start. There are times you have to clear out some of saw dust from them though. I also mounted a double bulb T5 light above my saw. It's bright enough to shine through the little holes and help you find them.
Like Zen, I only drill 10 to 15 holes at a time into the planned pieces that I want to cut at that time. And so most of the time it really doesn't matter if I thread the "wrong" hole because that piece was meant to come out at this cutting session anyway. Doing so also assures that I won't be sitting at the saw until every last hole is cut, no matter how long it would take to do this.
If a hole fills up with dust, an awl clears it out quickly.
If a certain hole amongst others MUST be cut first, I might just touch it with the tip of a Sharpie.
I thread my blade through the back of the the project, and not being sure of the terminology, I'm guessing that I am a bottom feeder.
Works for me.
Bobby
