Doug Posted May 14, 2015 Report Posted May 14, 2015 Nebraska - The Good Life is a pattern from BobScroll and the other two I borrowed most of the words from patterns by BobScroll. Thanks Bob. Scrolling Steve, bobscroll, Phantom Scroller and 2 others 5 Quote
amazingkevin Posted May 14, 2015 Report Posted May 14, 2015 Nebraska - The Good Life is a pattern from BobScroll and the other two I borrowed most of the words from patterns by BobScroll. Thanks Bob. gardening i tried it died.JPGgardening is a work of heart.JPGnebraska the good life.JPG Very good scrolled words DOUG, BOB will keep you busy! Quote
DWSUDEKUM Posted May 14, 2015 Report Posted May 14, 2015 Nicely done Doug. You need one more ... Should I mow the lawn or call it a garden? Thanks for sharing these with us. DW Quote
Scrolling Steve Posted May 14, 2015 Report Posted May 14, 2015 Looking good, Doug!...Is that cut from 3/4 stock!? Quote
bobscroll Posted May 14, 2015 Report Posted May 14, 2015 Hi Doug, Excellent scrolling! And I like the way you did the others in a different way, Bob Quote
Phantom Scroller Posted May 14, 2015 Report Posted May 14, 2015 Doug these are good to stick on side of the garden shed. Roly bobscroll 1 Quote
Doug Posted May 14, 2015 Author Report Posted May 14, 2015 Thanks for the comments. On "I Tried, It Died" the top right is supposed to be a dead plant which I do not think turned out very well but then maybe that is okay for a dead plant. Steve - it is all 5/8 walnut and cherry. I used to cut thicker but now I plane nearly everything to 5/8. Roly - I think you need Bob's original patterns to stick on the side of the shed; these are to small. DW and Marge - on another topic I got onto Judy Hunter's flying pig by an earlier post made by Marge and got it from Judy. I will probably not change my avatar but I really like her version of a happy flying pig better than mine. I did her pig but altered it to sit only on the word "Believe" done with Hobo font. And from the other post, I think it was Ike, if Ike sees this there is one house in Lincoln NE with plastic, ceramic, wood, and cast iron flying pigs so they are not just in Cincinnati. Quote
