danny Posted May 25, 2015 Report Posted May 25, 2015 (edited) I know there are different methods for keeping blanks together while scrolling, but just decided to snap pics to show my way. Might a been around a long time, but want to say I have experimented with other ways. Aileens glue sets up in less than 5 minutes. Ready to cut. And also after using different ways to attach a pattern I have decide this is the best for me. Sand blanks. No tape on blank. Spray pattern lightly. Attach and cut. The pattern usually peel off easily, but if not a spray of Minerial Spirits does the trick. Haven't seen this subject in a while, so Discussion Time. Danny :+} SECOND PIC SHOW JUST A LITTLE BITTY DROP OF GLUE IN EACH CORNER. Maybe this gluing method only works for circle or oval patterns. Edited May 25, 2015 by danny oneleggimp 1 Quote
oneleggimp Posted May 25, 2015 Report Posted May 25, 2015 Thanks - as a "Newbie" I'm glad to learn this. Quote
dgman Posted May 25, 2015 Report Posted May 25, 2015 Looks like an easy way of doing it Danny. I clamp the stack together first, then using a hot glue gun apply a bead of hot glue to the edges of the blanks. By the time I finish the last edge, the other edges are cool enough to remove the clamps. No waiting time at all! I do use Aleene's tacky glue for everything that needs gluing except when laminating boards together. For that I use Titebond III. Quote
merlin Posted May 25, 2015 Report Posted May 25, 2015 I'm with dgman on the subject, as for Aleene's tacky glue I think down here it's pva glue ***Merlin*** Quote
danny Posted May 25, 2015 Author Report Posted May 25, 2015 Thanks for the comments....AND.... Always Happy when DG gets back into our Chats. Dan only thing I have against Hot Glue is on the comic side Its downright HOT! And Smells some. Another funny. Hehe....but.... CAN see this method working very well. I never did this..BUT..I shall soon and get back here afterwards. Thanks .... Danny :+} Quote
dgman Posted May 25, 2015 Report Posted May 25, 2015 Hey Danny, my shop is in my garage so odor is never a problem, but today's glue sticks really don't have an odor. As for it being hot.... Yeah it's hot, don't touch it! wombatie 1 Quote
Kepy Posted May 26, 2015 Report Posted May 26, 2015 When I'm cutting something like that in a stack, the brad nailer works great in the scrap areas. I still use the blue tape under the pattern as it leaves the surface cleaner. Quote
LarryEA Posted May 26, 2015 Report Posted May 26, 2015 Danny, That sounds like a great method and if it works for you, stick with it. And I like the idea of hot glue on the sides. Quote
WayneMahler Posted May 26, 2015 Report Posted May 26, 2015 I still use masking tape around the stacks I cut and cover with blue painters tape. I have talked to other scrollers that use the hot glue and they are happy with it. Seems what ever works for you is the best way to go Quote
ike Posted May 26, 2015 Report Posted May 26, 2015 I always use screws to the salvge when done i remove the screws to use next time Quote
