Check out Half Priced Books as well.  They a lot of times have a surprising collection of scrolling books in stock.  I have seen this book in circulation among the many book collections on line as well.  I would definitely check the local library.. heck free is free :)
DW
Have you tried a rubbing of the shelf, i have done this to a few patterns.
lay a piece of paper over the original and rub it out with your finger then do a light pencil rub where you see the edges.
depending on the size of all the fretwork this may work in a pinch
Tha'ts the best I have at this time!
My take on this is If you still have the cutting on your wall can you take it down and carefully I said carefully take it apart.
Then copy it in the copier on the printer and if that don't work take a photo of the thing and then you get some smart designer to turn the photo into a pattern, then make two copies of said pattern and put the second one where you won't lose it.
Just my 2 penith worth.
***Merlin***
Ike;
  I checked the book that I have (Scroll Saw Shelf Patterns by Patrick Spielman and Loren Raty) .  The pattern that you are looking for is not in this book unless it is a different printing than I have. I have a couple of more books that have shelf patterns. I will try to locate them this week and check them out.
Ike, glad you were able to find the pattern you where after. I have to agree with you about our Village Family, there is always someone that knows the answer to any question. And they are all willing to help if they can. Thanks to everyone that responded to Ike's quest.
Dick
heppnerguy
