DWSUDEKUM Posted June 25, 2015 Report Posted June 25, 2015 Cut from 5 - 3/4 inch pine panels. The bank is 3 3/4" thick x 7" wide x 10" tall. The paints used are all water based acrylic. The bank was top coated with shellac. DW oldhudson, neptun, lawson56 and 4 others 7 Quote
amazingkevin Posted June 25, 2015 Report Posted June 25, 2015 Cut from 5 - 3/4 inch pine panels. The bank is 3 3/4" thick x 7" wide x 10" tall. The paints used are all water based acrylic. The bank was top coated with shellac. DW From bowls to banks your tops in the field! :thumbs: :thumbs: :thumbs: :thumbs: :thumbs: Quote
wombatie Posted June 25, 2015 Report Posted June 25, 2015 Is that a new design DW? I don't remember seeing this one before. Looks as good as the others though, I am sure the recipient will love it. Marg Quote
lawson56 Posted June 25, 2015 Report Posted June 25, 2015 I Love it! It Looks Fantastic! :thumbs: Quote
DWSUDEKUM Posted June 25, 2015 Author Report Posted June 25, 2015 Is that a new design DW? I don't remember seeing this one before. Looks as good as the others though, I am sure the recipient will love it. Marg Marg yes this is a new design. It was based on a bunch of tribute banks I was commissioned to do earlier in the year. This particular shape can be a brown bear cub, black bear cub, polar bear cub or a panda depending upon the color scheme. DW wombatie 1 Quote
Gordster Posted June 25, 2015 Report Posted June 25, 2015 I love these banks DW...When I see them I am like a little kid looking at a candy store.Like the way you signed it also. What do you use for the coin slot? The two banks that I have done have a wide coin slot. Quote
Scrolling Steve Posted June 25, 2015 Report Posted June 25, 2015 You are a Banker for sure DW !....Love the Bear! Quote
DWSUDEKUM Posted June 25, 2015 Author Report Posted June 25, 2015 I love these banks DW...When I see them I am like a little kid looking at a candy store.Like the way you signed it also. What do you use for the coin slot? The two banks that I have done have a wide coin slot. Gordie I take and drill two 2mm holes about 1 1/2 inches apart and then remove the wood between either with a spiral blade, knife , exacto saw or dremel. To ensure that the customer always gets a clean looking coin slot I will sometimes take a 2 1/4 inch long .025" thin 1 inch wide brass plate and with a jeweler's blade cut a coin slot in the brass plate then fasten that down with the same screws I use on the windows. That brass plate can cover a multitude of bad cuts DW DW Gordster 1 Quote
ike Posted June 25, 2015 Report Posted June 25, 2015 That is a great looking Bank Thanks for showing. Quote
bobscroll Posted June 25, 2015 Report Posted June 25, 2015 It looks great DW! Well put together, Thanks for showing, Bob Quote
Phantom Scroller Posted June 25, 2015 Report Posted June 25, 2015 DW you must be loaded with all these banks you keep making. I bet you have a giant Elephant one in your front room full of cash. Roly Quote
frankorona Posted June 25, 2015 Report Posted June 25, 2015 Another great work, it is a pleasure to see your work. Quote
