Thanks Smudger
wombatie
This is smudgers pattern.  I cut it in cedar which was a breeze to cut but it didn't take the finish too well. Oh well never mind.  Andrews made the pattern as a tie hanger but I don't have any ties just scarves, works just as well but for thinner scarves.  Thanks Andrew.
Marg
Very nicely done Marg.  I like that in cedar.  As for finishing for me at least I found that if I sealed the work with Tung Oil then a finish would go on.  Cedar is a one of those naturally oily woods so you either have to seal the wood so further oil does not make it to the surface or you need to use a solvent and remove the surface oils ( which will come back ) before finishing.  Thanks for sharing this with us.
DW
