That is great looking.  I could not see a break.  Great cutting.  What amazes me is I have looked at that pattern and thought nice, but not great.  Then I see what you did with it and that moved it to "great".
Edited by Scrappile
Nice cut Paul, no one will ever notice the break is not intentional unless you tell them. So never point out your mistakes!
I have cut several of those, they are a good seller!
Hey Bob, I always use a light colored wood for the overlay such as Maple, and a dark wood for the backer such as Walnut, Mahogany or Sapelee.
I always cut the inside cuts first, starting with the smallest and most delicut cuts, then the out side.
To make cutting easier, I will stack two or three layers of 1/4" material. This is called stack cutting. It makes the cutting more stable and you get multiple cuttings.
Edited by dgman
Looks good to me!
Very nice job and we all have to fix things as we go!
I have made fire wood from nearly complete projects that ended up beyond repair!
I am going to have to put something similar on my TRY -IT list.
Paul excellent job.  I agree somewhat with your that it might pop a bit more if there were more definition in color.  I think perhaps if either the horse or the backer were a couple shades darker it would stand out proudly.  I do like it just as it is though.  Thanks for sharing this with us.
DW
Thanks chaps for all your nice comments.
Agree with you all. It needs a little colour. Unfortunately I don't have any type of stain with me. I will get it done and then do the glue up.
Next time I will do what Dan does and use different coloured woods, I will also stack cut.
Here's a photo of one I cut. The overlay is quarter sawn Sycamore, and the backer and stand is Black Walnut.
Hi Dan. A beautiful example. ðŸ‘
I will revisit this pattern with some good quality wood.
Kevin, Frank & rjR. Thanks for your comments. 😉
All the best.
Paul
Paul very nice cutting will have to give it a go some time.
On another note: I see you have the same saw as me, what I done with the hold down foot is I left the rod on the saw and just removed the foot , so when you are tightening the blade with your thumb your other fingers wrap around the rod for more control.
If that sounds not right I'll post a pic later today.
***Merlin***
Hi Paul I use a light oil like 3 in 1 but most of the time I use oil air tool oil.
Here's the pic of my tattooed hand clamping the blade lever down while my fingers are around the foot rod, it just makes it easier to use the lever.
***Merlin***
Edited by merlin
Gordie & Marg. Many thanks. ðŸ‘
@Merlin. I'm glad you put up the pic. For some reason I was thinking you were talking about the knurled quick release. 😳
I will dig out the part and put it in place and give it a try. ðŸ‘
Cheers
Paul
