I cut down our macadamian tree down that died.?The trunk is 10" .Any tips on cutting it for small project and drying tips.I have a 10" table saw and a 12" blade that might fit with modifications?post-1607-0-73797400-1436721600_thumb.jpg
Edited by amazingkevin
I normally use my band saw but it has a 6" cut heighth. I have rer-sawm wood on my table saw but at 10 inches
yoiu would have to finish the cut by hand. Lots of work. If you have a mill close to you may ask them to slice it down. I understand they do this fairly cheap.
Kevin, with what you listed for tools that you own to do this with, I suggest you leave it be. It's just to dangerous to try to mill this size of piece, with your tools. It would be best to try to find someone with a bandsaw, maybe they will mill it for you.
Len
If you have access to a chain saw you could cut it down to manageable sizes.  But, in my opinion a table saw is not for milling ruff wood.  Someone with a band saw would make the whole process easier and safer.   Drying is, like mentioned a long process.
Ok Great ! i just wanted to throw it out there and see my options.Maybe a small piece for a key chain  will do.I had wanted to make   box for jewerly but to much involved ,Thanks everyone.I don't ;like dangerous stuff any more.Among other stupid things i've  done the worst was taking down the 50,000 volt  power line in the middle of super bowl  sunday back then.I had to leave quick cause if the wire didn't kill me the neighbors would have to miss their  program.It did blow me off the aluminum ladder right after the front of my face was full of fire flies in the day time!
I'm not waiting a year and my band saw is a mini one thanks!
I don't know about cutting it but the drying takes about a year . you need it dried to about 8% moisture or it might warp on you.
Thanks IKE,i remember you saying tht about the drying time with the recent wood you just got from the mill,Thanks!
Len
Most of my tools have got me one time or another except the band saw and table saw.Sounds like the table saw would have got me this time ,Thasnks!
The tree did cut easy ,Maybe i could set up a chainsaw to cut the logs? Ill think about that one,Thanks
