A couple of years back Ron Brown had a True Type font for key chains on his site. Unfortunately the site doesn't work any more. Does anyone have a copy of the font they could let me have please. Magic
Thanks Travis. I managed to track Ron down last night on a site called coolhammers.com and he sent me a copy of the font. Unfortunately it doesn't work well for MS Word or Corel WordPerfect. You have to type it in at larger than 72pt and then resize it for printing. Reduced to less than 72pt looks like blank screen with a few specks on it. Its a hollow font with very fine lines. Thanks for the help anyway. It was worth a try as I had only seen the results - a great font to cut. Magic
If you need it smaller than 72pt font, you can try using Inkscape. First type in the name at 72pt. Then go to Path>Object To Path. This will remove the "font properties" and turn it into an object. Then you can resize it to any size you wish. To thicken or thin the lines, you can adjust the stroke width by double-clicking the stroke color box (lower left corner of the screen). Click the Stroke Style tab and choose the width of the stroke. I don't have the font, but it should work.
