Is it my saw?
CATRK
I've been doing a lot of cutting of signs and ornaments and my go to blade tends to be a 3 or 5 FDUR. I have very few issues with these and they cut great. Recently i started trying to cut smaller more intricate work which require a smaller blade a #1 or 2/0. I can't seem to keep these blades on the saw without breaking for more than a minute. Most of the time they break when i turn on the machine. I'm using double stacked bb plywood so i know it's not the wood and like i said they break even before engaging the wood. I've tried taking the tension way down and that doesn't help either. Any input would be great
Saw is a porter cable
With a very small blade like those a high C tension is too much for them.  I use jeweler's blades a lot and I have found that on my dewalt which has a 1 - 5 tension scale that if I put the tension much past 3 the blade breaks quickly.  You might wish to try lowering your tension to about 1/3 of what you normally have it set to.  The other thing is speed.  The faster the speed the more the blade will wobble at the lower tension so you will need to slow your saw speed down a bit.  Those thin blade can only handle so many flexes back and forth before they break.  Hope this helps a bit.
DW
thin blades and thin wood like slow speeds.Try starting out slow and speed up after it starts.Starting out fast snatches the blade and any sloppiness in the machine get compounded to the blade .Which will pull the blade loose as soon as you start it up on fast speed  is what it sounds like to me.I've had years of experience with lower cost machines and found this to be true.Just my 2 cents worth.
A problem that occurs quite often is the set screw that backs up to the thumb screw backs out. This leaves the blade up against the thumb screw and a hole. If the blade is breaking at the blade clamp, this is what's causing it. Check to see if the set screw has backed out. Use what ever tool is needed to set it so it just protrudes past the hole.
I frequently use 2/0 and 1 and 2 size blades at all speeds tensioned to high C without breakage so tension and speed should not be an issue.
Dan hit it on the 'nose'.  I'll bet Marg's bottom dollar (or whatever currency she would use) that the set screw has moved.
Since your issue at at the clamps. I would check the set screw and make sure it is tight and also flat. Have had issues from usage were the set screws deloped a slight edge to them leaving a sparp edge and causing problems. A quick touch up with a flat file or sandpaper and a steady hand do the trick. I also use a porter cable and think they should have hardened those screws more then they did.
Ok. i looked at the set screw and sure enough there was a small burr on surface.So i decided to grind it flat on the grinder. Boy those things fly through
the air really well, never to be found again, so now my sawing is on hold until i can get another set screw. LOL.
 I don't think you ever want to grind one of these.   I would suggest that you use some sandpaper or a cardboard nail for taking out any burrs. But I guess you have probably figured that out by now.
Dick
heppnerguy
  • 2 weeks later...
