Blade problem
olddust1
I believe it's a related problem of the blade coming loose.fix that you should be back in business.Could be the oil on your finger tips where you pick up the blade to install it.
I have a problem with blades kinking below the table and pulling out of the top clamp.
I have installed a new clamp repair kit.
EX 21
John
Old Dust
i have found with my EX 21 sometimes I get the blade just into the position but barely. I have done it with top but more with getting in the top first then don't reach bottom correctly and pulls out. and this may not happen with every blade just some I measure thinking they are short some how but not. If I have a blade doing this I just make sure I have enough blade in the top and then will loosen the tension a little and see how it fits below and then tension. I hope I made some sense. I just make sure there is just a little more than just the very tip in the holder.
John, if the blade is bending from front to back or vise a versa, it's more likely the tiny tip insert in the blade clamp screw. When the blade clamp is being tightened up against the blade, the tip of the screw is supposed to turn so that this doesn't happen. I don't think that the tip in your clamp screw is rotating against the blade, I think that it is twisting the blade instead. If this is what's happening when you tighten up the screw, then it can and most likely will pull the blade out of the top blade holder. Try twisting the little tip on the screw, if it rotates without much effort, then I doubt that this is your problem.
Now, if your blade is bending from side to side, it's much easier to fix, it's just a matter of adjusting the set-screw on the blade clamp. It's the screw that is on the left side of the clamp, opposite from where the clamp screw is installed. Either one of these two issues can cause the problems that you are having, hopefully one of these two fixes will correct the problem.
Len
