A mistake
Kepy
I should have learned that it isn't always correct to listen to others ideas.  I was working on some cedar given to me that was sawmill cut and not all clear.  In order to locate the pattern in clear areas, I decided to glue the pattern directly to the wood and then remove it with mineral spirits.  I'm aware that some of you like that but it created a big mess.  The pattern lifted but not the glue.  I am used to being able to sand immediately rather than wait for the glue to dry.  It's back to the painter's tape for me.
i MIX ACETONE AND MINERAL SPIRITS TO GET OF THE PATTERN AND GLUE IN ONE SHOT.And then a quick wipe with a paper towel and it's clean as a whistle.Maybe your using a water based glue .Th mineral spirits and acetone wont touch it and makes a mess .I will never use tape!Ever!
