I do not use adhesives on patterns.
I use clear packing tape on the area of the wood that are going to get cut lines. Then I use a permanent marker on the tape to put the pattern to the wood. (I make a lot of templates up for anything I am going to do a repeat of.) I use the markers around the templates on to the tape. The tape peels off easily and a slight miss of a line does not even show!
Dollar Tree has a good tape for this at $1 each. Look the tape over though; and if bubbled of the roll or not smooth --take one that is. Those have had too much light exposure and will break instead of unrolling right.
You can also just staple a pattern in the waste area without any damage to the project.
the clear tape also acts a a blade lubricant. Do not buy the blades at the local store! Buy them on-line from a reliable source.
Here is the web site of my favorite supplier. http://www.pozsgaidesigns.com/contact.htm
He is a good, fair dealing man and I actually know him.
Hey Josh, go to 'General Scrollsawing' (here in SSV) and in the upper right is a 'Search'
Type in "Attaching Patterns"
There are a lot of POSTS on this subject.
1) some use spray glue and attach directly to the wood. Remove with mineral spirits
2) some use Blue painters tape over the wood and attach pattern with spray glue to the blue tape.
3) and there are other methods..........
And most do cover the pattern with clear packing tape.
And welcome....good to have you
Edited by LarryEA
Kudos to you Larry! This really helps!
Ya make me blush....:D
WE love questions and pictures....
Many many scrollsaw questions have been asked and you can always do that "Search'  but there are lots of times you will get
a different and maybe bettter answer by posting a question.
Welcome Josh.  Nice to see a youngster interested in the hobby.  What kind of scrolling do you like to do?
I mostly do pictures/portraits so my answers below are related to that type of scrolling.
Like others are saying, there are many methods and most have their preferences. I no longer use clear packing tape over my patterns, but if it is a very delicate pattern I do use blue painters tape.  If not I put the pattern directly on the wood.  I feel the painters tape helps hold the delicate stuff together, coarse you have to be very careful when removing it.  I use 3M 77 spray adhesive but there are others that probably work just as well.
I have not tried double sided tape.  I would be concerned about the sawdust getting to it and the pattern lifting up.  I would also worry about removing it from the wood once the cutting was complete, because any double sided tape I have had, really sticks.  Those are my concerns, but does not mean it wouldn't work, like I wrote, I have not tried it.  One other thing is it is expensive.....
Welcome to the village Josh. I use a spray glue 3M or something similar. and remove with mineral spirits when finished. There is also a paper a couple pattern companies sell I think they call it scrollers tape. Its just a big label you print directly on it peel the back off and stick it to the wood. I have used it a couple times and it peeled back off pretty easy. here is a link to a couple.
http://www.woodenteddybearonline.com/x/product.php?productid=4463&cat=&page=1
http://www.woodenteddybearonline.com/x/product.php?productid=7219&cat=220&page=1
Hi Josh, welcome to the Village.  I'm Marg from Australia.  Its great to see some young blood here :thumbs:   You have already had some great advice so I will leave it at that.
Marg
Well Josh,
   as you can see there are a lot of different ways to attach a pattern to wood. Allof them work and it is a matter of preference, this you learn by trial and error. I used blue painters tape and a glue stick for years and thought it was the best way there was, at least for me. a few months ago I started using a spray glue on the back of the patterna nd then putting it directly on the wood. when I am finished cutting my pattern I use a small sponge brush dipped into paint thinner and paint the moisten the pattern completely and wait about 15 seconds and the pattern falls off in one piece, I then take a clean rag and wipe the moisture from the wood, If however I find that i used the spray glue to generously and there remain a little bit of stickiness on the wood, I simply dampen my rag withthe paint thinner and wipe away the residue. you need to let the finished piece dry before you sand or finsh it.
I have found that Harbor Freight sells a spray glue in a large can for under $10 that works really well, it is made by a company named CRC. It is cheaper than the other glues mentioned above and I have found no fault with it at all
Dick
heppnerguy
Josh there are so many ways to stick the patterns on wood, all I can say is do what's best for you. I use re-positional spray glue on the pattern stick it to the wood and cover in two inch selotape and have never had any issues with it coming off ,I love this method but each to his/her own I say. I guess you have another 70 to 80+ years to get it right. :lol: Roly
Edited by Phantom Scroller
